Fuel Problem?
Old May 29, 2008 | 02:32 PM
RotiEatter's Avatar
Ditto
Default Fuel Problem?
Ok im working on a friends LS swapped 92 hatch. I changed the intake manifold to a stock one, now when i crank the car it barley wants to start and idles decent for a min then dies. All the plugs are in the correct place. No CEL. The car starts with the help of starter fluid, without that it really doesnt want to start. When it is on and you rev the car bogs and wants to die.
Checked for fuel at the rail and its there. But here is the weird thing, i took of the return hose and its bone dry, then unbolted the stock FPR and fuel sprayed out like crazy. What can this be? Clogged injectors(they are stock)? It was fine before, im really stumped, any help appreciated!
Old May 29, 2008 | 02:36 PM
chimmike's Avatar
Default Re: Fuel Problem? (RotiEatter)
uh, is the FPR adjusted too tight?
Old May 29, 2008 | 02:51 PM
RotiEatter's Avatar
Ditto
Default Re: Fuel Problem? (chimmike)
its just the stock regulator..sorry shouldve clarified
Old May 29, 2008 | 03:03 PM
inspyral's Avatar
Are you sure you didn't mix up the TPS and MAP sensor plugs when you put it back together?
Old May 29, 2008 | 03:12 PM
RotiEatter's Avatar
Ditto
Yup
Old May 29, 2008 | 03:16 PM
Turbogixxer's Avatar
Pull the plugs. See if it is running rich. If it is, your FPR is bad.
Old May 29, 2008 | 03:34 PM
RotiEatter's Avatar
Ditto
Default Re: Fuel Problem? (Turbogixxer)
Tried an extra regulator I had laying around and still the same problem.
Old May 29, 2008 | 03:36 PM
Pull the plugs and see if just one or a few cylinders are misfiring. Once you find the cylinder, it should be easier.
00Civik
13
Aug 22, 2011 06:37 PM
riceburner700
Mar 15, 2007 04:56 PM
RuskeR
Oct 24, 2005 03:03 PM
moridin2004
Feb 2, 2004 02:48 PM
