12.7:1CR do-able with 91 octane?
Old Oct 5, 2004 | 11:38 AM
*Boostwerks*'s Avatar
Default 12.7:1CR do-able with 91 octane?
I am building up a Y8 ITB motor, and am looking to put in some PM7 pistons. utilizing a .048" headgasket I got a 12.7~ compression ratio.
Because I need to keep this streetable, can this work with 91 octane?
TIA!
Bryson
Old Oct 5, 2004 | 11:39 AM
aznboysrfr's Avatar
definitely not, imo
Old Oct 5, 2004 | 11:42 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: (aznboysrfr)
Wow, that compression seems pretty dang high for pump gas .. i'm curious to see what others say about this.
what is the highest compression you can run on pump gas with good tuning? Sorry if this might be OT
Old Oct 5, 2004 | 11:44 AM
Also keep in mind that I'm at 5800ft.
I was just thinking that since you can run a lot of boost on 10:1CR I would think 12.6 n/a would be nothing if I tuned it a lil rich.
Old Oct 5, 2004 | 12:47 PM
Oh I guess I should also mention that I am going to be using a Zex 105300 Street/Strip Camshaft, so I'm sure that changes the dynamic compression.
Old Oct 5, 2004 | 01:05 PM
Waachback's Avatar
It can be done with a good tune.
Old Oct 5, 2004 | 02:26 PM
Veris's Avatar
Default Re: (Waachback)
Agreed. I'm running 12.4:1 CR with 91 octane.
Skunk2 Stg 2 cams. B series. At 1600ft altitude.
No detonation.
Make sure you tune with a wide band o2 sensor.
Old Oct 5, 2004 | 02:45 PM
pro4machine's Avatar
Default Re: (Veris)
Really it depends on the camshaft. If you run a cam with lots of overlap, you can get away with with it. Before I switched to a Twin cam, I had a D16Z6 with 12.0 compression. With the stock cam it detonated everyplace I went. When I installed the JG 85VT80 cam, problem was fixed and picked up a bunch of power.
Old Oct 5, 2004 | 04:14 PM
johnzm's Avatar
Default Re: (pro4machine)
bryson, ive noticed that igntition timing has a bigger role in detonation/ping on n/a build than fuel. if u can slot out your distributor enough to pull out timing u can run any compression you want! im running 13.5 on 93 octane with somewhere like 12 degrees timing. dammit i need to buy a digital timing gun!
Old Oct 5, 2004 | 10:01 PM
Default Re: (johnzm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnzm &raquo;</TD></TR><TR><TD CLASS="quote">bryson, ive noticed that igntition timing has a bigger role in detonation/ping on n/a build than fuel. if u can slot out your distributor enough to pull out timing u can run any compression you want! im running 13.5 on 93 octane with somewhere like 12 degrees timing. dammit i need to buy a digital timing gun!</TD></TR></TABLE>
Yeah thats what I assumed. N/A setups are new to me, but I've been boosting for a long time, and since you just retard the timing with more boost, thats what I would assume you could do for a high CR setup.
I guess I'll give them a try, retard the ignition a few degrees from stock, and tune her to the sweet spot from there...
Old Oct 5, 2004 | 11:26 PM
gutted's Avatar
Default Re: (Bryson)
93 octane 12.3 cr. runs fine. 12.7 could be do-able if you run really retarded i suppose.
norcalbayboy
29
Aug 7, 2006 10:08 PM
kidd_drastic
23
Feb 3, 2006 07:59 PM
bpowa
Jul 18, 2004 07:28 PM
AllMotorITR
Sep 30, 2002 09:33 PM
Rocket
May 5, 2002 12:32 PM
