Need infos.?
Old Oct 5, 2004 | 11:33 AM
92_EGhatch's Avatar
Default Need infos.?
Well i have a problem with my engine. It kept on overheating and i don't really know what i should do. So I went to the mechanics and they said that my head gasket is not good, so nether i change it our get a new Motor. So i decide to change my head gasket, intake manifold gasket, thermostat and the radiator. After i got itt done and drove it for almost a months and then couple days ago it started to overheat again. So when it does that i ususally turn on the fan to cool the temp. down. But it only works for a while. [B]SO I NEED HELP??????????????[/B[B]
Old Oct 5, 2004 | 11:42 AM
redlinetuning's Avatar
Default Re: Need infos.? (92_EGhatch)
assuming you have a sohc d16 motor, and knowing you've already changed the thermostat and the radiator, have you checked the fuses ? might have a bad fan, or broken fuse somewhere.
more information would help
Old Oct 5, 2004 | 11:45 AM
92_EGhatch's Avatar
Default Re: Need infos.? (redlinetuning)
NAh.. i swaped a B16a3 delsol motor in my EG... Well i checked the fuse box already and everything is sitll good.
Old Oct 5, 2004 | 11:46 AM
m3dia_lab's Avatar
have u checked to see if the fan comes on?
Old Oct 5, 2004 | 11:55 AM
92_EGhatch's Avatar
Default Re: (m3dia_lab)
yes. only the radiator fan came on... but still don't know whats wrong.
Modified by 92_EGhatch at 1:14 PM 10/5/2004
Old Oct 5, 2004 | 07:54 PM
mdj_ge's Avatar
Default Re: (92_EGhatch)
go check this out... https://honda-tech.com/zerothread?id=1013625
Ldo
10
Jan 7, 2009 07:42 AM
allmotor65stang
Jun 19, 2008 02:41 PM
Marauder
May 25, 2006 01:09 PM
juicedricer
Jan 21, 2003 04:55 AM
kento
Jul 16, 2001 05:15 PM
