bolting on aebs intake manifold
Old Oct 5, 2004 | 04:28 AM
HamiltonRex's Avatar
Default bolting on aebs intake manifold
Ive got a CTR cylinder head on a GSR block. Right now im running a completely stock 1st gen b16 intake manifold and TB setup.
What parts will not beable to transfer from my current manifold to the aebs one? Will i need a new fuel rail? Or what.
Any coolant lines have to be re-routed (im not running an oil cooler), the IACV and other sensors, mount up in the same place?
Thanks! Should beable to see some good gains with this piece of my current manifold.
Old Oct 15, 2004 | 12:29 AM
Reelizmpro's Avatar
Default Re: bolting on aebs intake manifold (HamiltonRex)
There's no provisions for the FITV on the AEBS manifold which means you either run without it or get a TB with it attached like 60mm OBD1 GSR or USDM B16A. You may want to go this route and have it ported to 64mm while you're at it since the AEBS inlet is 65mm. This is what I'm doing now. Since the IAT sensor is moved to the #2 runner, it may hit the FPR which is why people say to change over to the later style rail with the FPR on the end.
Old Oct 15, 2004 | 03:47 AM
Default Re: bolting on aebs intake manifold (Reelizmpro)
I have a ITR fuel rail that i could use. Thanks
Old Nov 1, 2004 | 12:57 PM
LoSt is BlaCk's Avatar
if your gangsta enough you can also dremel some of the plastic off of the sensor to make it all fit together while still using the 1st gen fuel rail...this is no easy task...i stood back and watched h-t member "fobtions" handle it...
ctr83
Dec 28, 2007 02:11 PM
jon3zy
May 4, 2007 07:17 PM
GTCNDY
Mar 15, 2006 05:15 PM
CarAudiophile
Feb 3, 2004 05:01 PM
proto
Oct 18, 2001 10:18 PM
