where is the tranny code?
Old Oct 4, 2004 | 11:26 PM
IVI's Avatar
IVI
Default where is the tranny code?
searched.
where do you find the code on the tranny?
Old Oct 4, 2004 | 11:31 PM
eg6sir-s's Avatar
Default Re: where is the tranny code? (IVI)
there should be a white sticker with barcode around the bell housing of the tranny. just above where the vin plate is located in other words just above to the left of the block stamp.
Old Oct 4, 2004 | 11:47 PM
IVI's Avatar
IVI
Default Re: where is the tranny code? (eg6si)
my sticker was like a reflective aluminum color but i accidently wiped out whatever it said with brake cleaner a long time ago.
Old Oct 4, 2004 | 11:51 PM
eg6sir-s's Avatar
looks like you found your answer.
Old Oct 5, 2004 | 12:01 AM
IVI's Avatar
IVI
is that the only spot where they put the code? on a sticker ?
the brake cleaner cleaned my sticker off, cleaned the ink off too, now its just a plain clean sticker.
there is no other way to find out ?
Old Oct 5, 2004 | 12:04 AM
eg6sir-s's Avatar
what motor and car(chassis) do you own? did you do a swap and not know or remember what tranny came with it?
Old Oct 5, 2004 | 12:30 AM
IVI's Avatar
IVI
its a 96 db8 , jdm b16.
cant remember what tranny came with it
Old Oct 5, 2004 | 12:45 AM
eg6sir-s's Avatar
http://www.ff-squad.com/technet/
look under: B-series Gear Ratio Guide
Old Oct 5, 2004 | 12:52 AM
IVI's Avatar
IVI
thanks for your help so far, but i dont understand reading the gear ratios.
i can eliminate the last 4 which are cable since i know its a hydro
other than that, im not sure...
Old Oct 5, 2004 | 01:04 AM
eg6sir-s's Avatar
is it that you just want to know what it is you have or do you need to know what tranny you have because of maintenance issues?
Old Oct 5, 2004 | 01:19 AM
IVI's Avatar
IVI
just wanted to know what exactly i have.
Carbcivic
Nov 13, 2007 06:30 PM
sexyblack93lude
Jul 5, 2005 08:18 AM
arielmalespin
May 29, 2005 05:44 AM
anfrey
Nov 11, 2004 08:07 AM
