my spark plugs quest pictures inside...
Old Oct 4, 2004 | 10:55 PM
yeegsr's Avatar
Default my spark plugs quest pictures inside...
this is my current spark plugs are the NGK-Iridium IX BKR6EIX-11 <---- i have it for like 3months....show below all black.....my engine running pretty rich for stock...
my question is that number 11 represents the heat rang of the spark....11 is the coldest of all heat range....
my engine is pretty much stock just some bolt on CAI/h/e that is it....heat rang of 11 is not the way to go right....?
what heat rang do you guys suggest
Old Oct 4, 2004 | 11:01 PM
@ries's Avatar
Default Re: my spark plugs quest pictures inside... (yeegsr)
NGK ZFR6F11
Old Oct 4, 2004 | 11:08 PM
yeegsr's Avatar
Default Re: my spark plugs quest pictures inside... (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">NGK ZFR6F11</TD></TR></TABLE>
what is that heat rang looks like 11 too....my engine is stock should it run that cold
Old Oct 4, 2004 | 11:20 PM
@ries's Avatar
6 is the heat range... 11 means it pregapped at 1.1 mm
Old Oct 5, 2004 | 12:53 AM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">6 is the heat range... 11 means it pregapped at 1.1 mm</TD></TR></TABLE>
what about my spark plugs...NGK-Iridium IX BKR6EIX-11, is the 11 is the gap or heat range....
thanks
Old Oct 5, 2004 | 01:03 AM
@ries's Avatar
That should mean that those are pregapped at 1.1 also... 6 is the heat range.
Old Oct 5, 2004 | 01:08 AM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">That should mean that those are pregapped at 1.1 also... 6 is the heat range.</TD></TR></TABLE>
thanks so much...aight man time for sleep gnight
Old Oct 5, 2004 | 07:57 AM
arw321's Avatar
Check your plugs at WOT.
Old Oct 5, 2004 | 08:26 PM
yeegsr's Avatar
Default Re: my spark plugs quest pictures inside... (arw321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">Check your plugs at WOT.
WOT where? is that a site...or forum..
Old Oct 5, 2004 | 08:58 PM
b19coupe's Avatar
Wide Open Throttle
Old Oct 5, 2004 | 09:25 PM
marieT1GRL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
WOT where? is that a site...or forum..</TD></TR></TABLE>ooopss.. j/k
Old Oct 6, 2004 | 02:50 PM
PreStaged12s's Avatar
yeah the 6 is the heat range, I was running 8s sometimes 9s with my GSR, s2s3s, 20 degrees advanced timing on 91 octane.
Old Oct 7, 2004 | 08:12 PM
yeegsr's Avatar
Default Re: my spark plugs quest pictures inside... (PreStaged12s)
coolllllllllllllllllllll...thanx for all the gang of H-T's input
Old Oct 7, 2004 | 11:25 PM
blk_db2's Avatar
Here's what each "letter" and "#" means....
http://www.ngksparkplugs.com/t...y.pdf
Old Oct 11, 2004 | 12:06 AM
yeegsr's Avatar
Default Re: my spark plugs quest pictures inside... (blk_db2)
cool thanx so much...i went there before but coud,nt find it...thanx man
crazybeanery0
Sep 6, 2024 06:47 AM
Midori Green
16
Apr 29, 2008 07:24 AM
Boostage
Aug 5, 2006 11:11 AM
EikoU
Oct 12, 2005 09:50 AM
itr817
Jul 26, 2003 06:10 PM
