for all the turbo h22 people
Old Oct 4, 2004 | 10:53 PM
whp
Guest
Posts: n/a
Default for all the turbo h22 people
set up:
Fully built h22 9:1 89mm
-Golden Eagle sleeves
-je pistons
-Crower rods
Im going to run a strait t4 sc61 with an sst
i plan on making around 480whp for the track and around 340whp for the street
-injectors-precision 880's or 1000's?
-would a 38mm tial w/g be good enough?
-whats a good intercooler to run? thinking about the big precision (750hp) but it's kind of pricey. any ideas?
also what fuel pump can handle that amount of power? can a walbro 255 handle it? and should i go ahead and get a fuel rail? if so is the aem one good or any suggestions?
Old Oct 6, 2004 | 10:14 PM
whp
Guest
Posts: n/a
Default Re: for all the turbo h22 people (throwed)
Old Oct 6, 2004 | 10:34 PM
flip1199's Avatar
1000's
38mm is fine
Old Oct 7, 2004 | 06:45 AM
honda13typer's Avatar
Default Re: for all the turbo h22 people (flip1199)
yea 1000cc 38mm will do and precision makes a 650hp intercooler which is a lil bit cheaper. what are you tuning your car with?
Old Oct 7, 2004 | 06:46 AM
Default Re: for all the turbo h22 people (honda13typer)
from what i hear the walbro is good to about 450 any more and its pushing it.
Old Oct 7, 2004 | 10:28 AM
turboHX's Avatar
There is a sale on precision IC's this month check it out.
Old Oct 7, 2004 | 10:33 AM
PrecisionH23a's Avatar
I plan on taking my walbro up to around 600whp. Mase tuned a walbro up to 640whp before with no problems. Make sure you get the high pressure pump though.
Old Oct 7, 2004 | 10:52 AM
whp
Guest
Posts: n/a
Default Re: for all the turbo h22 people (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I plan on taking my walbro up to around 600whp. Mase tuned a walbro up to 640whp before with no problems. Make sure you get the high pressure pump though.</TD></TR></TABLE>
wheres the cheapest place to get a walbro, and the 255 is the high pressure pump right?
Old Oct 7, 2004 | 06:14 PM
v4lu3s's Avatar
RTFM
all walbro 190 and 255 come in normal or high pressure.
Old Oct 8, 2004 | 12:34 PM
PrettyLude's Avatar
http://www.lightningmotorsports.com
best place to buy walboros
Old Oct 8, 2004 | 08:08 PM
illuded's Avatar
Default Re: (PrettyLude)
That's a good setup that you wanna do there. 38mm wasgate either a tial or turbo smart wastegates will do. the walboro 255 fuel pump is sufficent enough. aem fuel rail and fuel pressure regulaor while ur at it. that sc 61 turbo is the same turbo i have in my setup. i'm running in to small problem like my clutch master flywheel gave out and clutch but on the dyno b4 it just stared making jingling noise was at 200 hp at 0 lbs of boost at 4200 rpms. yes it suck cause it so close to being finished.
good luck with ur set up. just hope u don't run in to the problems i ran into.
damn h22 motors are so diffrent.
hatche1
Oct 28, 2011 07:36 PM
lshatch59
Dec 24, 2006 11:15 PM
toyH22
Jan 27, 2006 04:06 AM
whp
Oct 7, 2004 09:39 PM
