Suspension noise, not squeeking but knocking. Shocks or bushings?
Old Oct 4, 2004 | 07:22 PM
zither's Avatar
Default Suspension noise, not squeeking but knocking. Shocks or bushings?
The noise is happening in the front driver side but it's only in an alley over pot holes or large travel distance of the wheel, it's a noise as if something is loose. I dont know if it's the shocks or bushings. And as for the shocks, i'm also changing them because the car has a lot of body roll, tires aren't the issue because i just got performance summer tires.
Old Oct 5, 2004 | 01:03 AM
IVI's Avatar
IVI
Default Re: Suspension noise, not squeeking but knocking. Shocks or bushings? (zither)
check your tie-rods and balljoints immediatly!
it could cause you to get into an accident.
Old Oct 5, 2004 | 05:08 AM
Greenery18's Avatar
Default Re: Suspension noise, not squeeking but knocking. Shocks or bushings? (IVI)
I am experiencing the same problem. It is more of a clunking than anything, and happens on certain low speed stutter bumps a lot. I think a mechanic noted that my LCA bushings were going bad, so that could be the culprit in your case...
Old Oct 5, 2004 | 06:38 PM
zither's Avatar
Default Re: Suspension noise, not squeeking but knocking. Shocks or bushings? (Greenery18)
What Greenery18 said is exactly what it is, low speeds and bumps. Is there any way to reproduce this noise by moving some part while the vehicle is raised?
Old Nov 5, 2004 | 01:39 PM
zither's Avatar
It was the ball joint connected to the upper control arm, couldn't replace the ball joint by itself but i got the whole arm for $30cnd from an auto wrecker, previous car had 34000 on the odo. Not a bad deal considering honda wanted $130cnd
Old Jun 8, 2005 | 05:39 PM
thrty8street's Avatar
i think im having the same problem with the noise. its only coming from the rear. i have an eg hatch by the way with omnipower full coils.
Old Jun 8, 2005 | 06:16 PM
slomofo's Avatar
GDD Member
Default Re: Suspension noise, not squeeking but knocking. Shocks or bushings? (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">i think im having the same problem with the noise. its only coming from the rear. i have an eg hatch by the way with omnipower full coils.</TD></TR></TABLE>
There's no balljoints back there buddy.
Oh, and greenery 18 - change your sway bar end link bushings.
*sorry for jacking your thread, bored off my ***.
Old Aug 4, 2005 | 05:21 PM
mildly.interesting's Avatar
radius rods not bolted in was my thing, check those too
Old Aug 4, 2005 | 09:37 PM
dakidhasSOL's Avatar
my friend has the same problem, and i was riding with him and i hear the squeaking and hissing kinda noise i think(in the front passenger side is where i heard from, not sure) and after a while stops and starts up again didnt really pay attention becuase it isnt my ride but im reading this anyway so ill help him out, so the prob is the ball joint connected to the upper control arm?
davey5300
Dec 28, 2009 11:06 AM
rEnZ94tEgGy
Suspension & Brakes
Apr 27, 2008 11:58 AM
GSRBrent
Oct 17, 2007 12:28 PM
WhtHatchBack
Jul 7, 2007 01:07 PM
Serenity Now!
Mar 2, 2007 02:06 AM
