Brake Problem??
Old Oct 4, 2004 | 02:02 PM
XzzYzzX's Avatar
Default Brake Problem??
I have a 92 civic dx, When i got the car the brake were very soft like you had to hit the floor to stop, Well they got worse so i replace the master cylinder, new pads, new rotors, Now i still have the same problem, they stop at the floor but not very good...what else could it be the soft lines? hard lines? brake booster, how could i check to see what else is working and not...thanks
Old Oct 4, 2004 | 03:19 PM
drdisco69's Avatar
Default Re: Brake Problem?? (XzzYzzX)
Try bleeding the brakes. Thats a common cause for a crappy pedal. Also make sure you use new, high quality fluid. Honda is good, Valvoline Syntec is better, Motul is best. Never use silicone brake fluid in any car ever.
Old Oct 4, 2004 | 05:13 PM
SiR Inspired ED7's Avatar
Default Re: Brake Problem?? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Try bleeding the brakes. Thats a common cause for a crappy pedal. Also make sure you use new, high quality fluid. Honda is good, Valvoline Syntec is better, Motul is best. Never use silicone brake fluid in any car ever.</TD></TR></TABLE>
Old Oct 5, 2004 | 01:07 AM
IVI's Avatar
IVI
hydraulic fluid is hydraulic fluid. any dot 3 brake fluid will do, i wouldnt reccomend wasting extra money on 'honda' brand.
did you bench bleed the master cylinder ?
Old Oct 5, 2004 | 04:50 AM
XzzYzzX's Avatar
Default Re: Brake Problem?? (IVI)
no, i just put the new mc on and bled the system 3 times so far....
Old Oct 5, 2004 | 06:12 AM
JimBlake's Avatar
If you don't bench-bleed the MC, it's very difficult to get air out of the MC. Either take it out to bench-bleed, or bleed the system a LOT more. Like maybe another pint from each wheel.
Better brake fluid has higher boiling points, but that isn't what your problem is about.
Old Oct 5, 2004 | 08:27 PM
drdisco69's Avatar
Hydraulic fluid is not hydrauilic fluid. Read the label on any two bottles of brake fluid or search on it. Having a 200 degree higher boiling point is sort of nice. Besides, Valvoline Syntec is half the price of Honda fluid, and has a higher wet and dry boiling point.
wduzak
Jun 5, 2017 04:58 PM
da1lydr1ver
Mar 26, 2012 06:25 PM
tazz29
Jul 9, 2008 10:52 AM
spintboy
17
Jan 3, 2008 08:49 AM
93CamaroLT1
Aug 16, 2006 09:28 AM
