custom manifold question
Old Oct 4, 2004 | 01:58 PM
eg6T's Avatar
Default custom manifold question
well me and a friend made a steel manifold,well i put it on the engine and a bolt wont go on because the runner blocks it,what should i do about this?how could i shave it down?thanks
Old Oct 4, 2004 | 02:39 PM
mattssi's Avatar
Default Re: custom manifold question (eg6T)
I wouldn't shave it any, you don't want to make the material any thinner. Heat it up slightly in that area, and make some gentle taps with something that has a rounded edge. Do some test fits to make sure you don't do too much. as too much of a bump will disrupt exhaust flow.
Old Oct 4, 2004 | 03:57 PM
eg6T's Avatar
Default Re: custom manifold question (mattssi)
thanks
Old Oct 4, 2004 | 04:28 PM
Canuk_SiR's Avatar
can you put a stud in the hole? tey a stud and just putting a bolt on the other side. In tight spots this works the best. Just make sure to use thread lock on it
Old Oct 4, 2004 | 05:22 PM
eg6T's Avatar
Default Re: custom manifold question (Canuk_SiR)
it fits,but there is no room to turn the nut
bopbop93030
Aug 12, 2009 08:22 PM
phthalo
May 24, 2007 11:53 AM
vietnogi
Jun 18, 2005 05:10 PM
95GSRTT
Feb 3, 2005 11:48 AM
GrandMarkie
May 17, 2002 12:53 PM
