high idle
i had a rip in my intake manifold gasket and i changed that out and cleaned my throttle body. i then found that i need a new pcv valve but then there is still a vac leak.
this is on a jdm gsr; i cant figure what else would have my idle at 1500 when warmed up
any suggestions?
any suggestions?
Try lowering ur idle speed. On the top of the throttle body there's a flat head screw. turn that screw clockwise to lower ur idle speed.
u might need to take a flat head screw driver and hit it with a hammer on that screw in order to turn it. the head on the screw is not deep enough to turn, so u might need to mave the groove bigger with the screw driver and hammer.
u live in Jamiaca queens? i live in Richmond Hill
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">Try lowering ur idle speed. On the top of the throttle body there's a flat head screw. turn that screw clockwise to lower ur idle speed.
u live in Jamiaca queens? i live in Richmond Hill</TD></TR></TABLE>
ive screw that damn thing all the way down and it cant go no more
and i dont want to replace each and every vac hose
i havent been by richmond hill in a while
