Ls hydro tranny with an aftermarket clutch kit and flywheel vs. 99-00 si tranny with stock clutch?
Old Oct 4, 2004 | 10:43 AM
94PearlWhiteGsr's Avatar
Default Ls hydro tranny with an aftermarket clutch kit and flywheel vs. 99-00 si tranny with stock clutch?
I have an ls hydro tranny on my GSR and I just wanted to know if I get an ACT clutch kit and street flywheel, will that be a good enough uprade. Or should I just invest in a 99-00 si tranny for the shorter gears. Tell me what you all think.
Old Oct 4, 2004 | 11:04 AM
Rod.'s Avatar
Default Re: Ls hydro tranny with an aftermarket clutch kit and flywheel vs. 99-00 si tranny with stock clutc
Do you still have your GSR tranny?? I bet a Ls tranny sucks on the gsr. I would go for the b16
Old Oct 4, 2004 | 11:50 AM
No I don't have it anymore but I wish I did because it seems like these gears suck especially 3rd. So I guess instead of buying an ACT clutch, pressure plate and flywheel, I should just buy a 99-00 si tranny.
Old Oct 4, 2004 | 12:13 PM
Rod.'s Avatar
You dont want another Gsr tranny?
Old Oct 4, 2004 | 12:49 PM
well I want to try something different. Thats why i want to go with a b16 tranny. Is there a big differrence between the Si and the GSR tranny?
Old Oct 4, 2004 | 01:10 PM
94teg_RS's Avatar
go with the b16 cause the gears are to long in the ls and the gsr are would be better than the ls, but the b16 is best
unless you get type r with lsd
Old Oct 4, 2004 | 01:26 PM
Default Re: (94teg_RS)
Thanks for the info guys. I'm just going to go with the 99-00 si tranny. This ls tranny that I have right now is slow with a gsr motor.
dc2vu
May 23, 2005 11:17 PM
.Ryan
Feb 22, 2005 09:51 PM
6shootahorsenamedtrigga
Aug 8, 2004 11:17 AM
incognitoracerr
Feb 15, 2004 09:42 AM
blazin
Mar 25, 2003 11:01 PM
