dc headers...4-2-1 or 4-1 for a 94 gsr which one is for prefered
Old Dec 13, 2001 | 06:37 PM
thaigsrdrv16's Avatar
New User
Default dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered
i was just wondering because im about to buy one of those but im not sure which one is better i heard 4-1 or more drag...but 4-2-1 is more "safer" for street is that tru???....jus lemme know wassup thanx peace~
INTEGRA GSR 94 RED
AEM CAI
RS*R INDIVIA EXHAUST
[Modified by thaigsrdrv16, 3:38 AM 12/14/2001]
Old Dec 13, 2001 | 06:51 PM
acuracer's Avatar
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (thaigsrdrv16)
4-2-1 = more low end
4-1 = more high end
Old Dec 13, 2001 | 06:55 PM
neo1z's Avatar
yea.....nothing is really safer than the other.....what are you looking for, most power, or most effective for the street?
like acur said 4-1 for most power
4-2-1 for all around
Old Dec 13, 2001 | 06:59 PM
Chris's Avatar
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (acuracer)
To clarify that post.....
4-1 will make PEAK power higher in the RPM range
4-2-1 will make PEAK power lower in the RPM range
Old Dec 13, 2001 | 07:09 PM
B00ST2nR's Avatar
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (Chris)
Go with 4-1 header! When you race, its all about Top end. You'll never be under 3k rpms when you race, so 4-1 headers will be the one. Plus, the top end feels so good with a 4-1 header.
I'm lookin for JDM 4-1 headers. If you got the money, get the JDM.
Old Dec 13, 2001 | 07:11 PM
New User
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (GS-Racer)
thanks...but i dunno i think i might hit up the 4-1 cause i do race laot and i do want more power....peace
Old Dec 13, 2001 | 07:17 PM
mojoGSR92's Avatar
The reason he PROBABLY mentioned safety is because a 4-1 header doesn't allow as much ground clearance. A 4-2-1 header only has to fit 2 pipes under the oil pan/cross-member (on my car anyways) while a 4-1 header fits 4 pipes under the oil pan/cross-member. This means if your car is "slammed to dah grizzound y0," you will be more likely to damage it.
As for performance gains 4-2-1 headers provide more midrange power over 4-1 headers. 4-2-1 headers don't yield as much peak horsepower as a 4-1 header. If you don't race, you'll probably prefer the 4-2-1. If you do, you'll probably prefer the 4-1. Either way, decided if you value your midrange or top end.
Old Dec 13, 2001 | 07:34 PM
StinkyTofu's Avatar
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (mojoGSR92)
does my car look like it has enough ground clearance for a jdm 4-1 header without scraping? i also plan on getting an apex n1, my car is lowered 1.5 in the rear and 1.75 in the front. i hope thats enough ground clearance.
Old Dec 13, 2001 | 07:41 PM
rodimus's Avatar
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (B-18C1)
that looks like enough clearance...unless you like to go off-roading
but i heard ALOT of good stuff about the JDM type R header...plus the fact that
it's tougher as far as if you hit a bump with the DC...it'll dent alot easier...i think
it might be due to the material/construction...once you dent your header...there goes your performance
Old Dec 14, 2001 | 12:06 AM
George H's Avatar
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (EVOL)
To pick a header, decide how far you want to modify. If you plan on settling with just bolt-on's I suggest you get the 4-2-1. If you plan on getting aftermarket cams and such, then you certainly want the 4-1 header, but 4-2-1 is good for a bolt-on setup.
Old Dec 14, 2001 | 08:22 AM
tonydatyga's Avatar
nice clean car, nice clean house, nice clean drop, wait... stock rubber?? Curse michelin for even making xgt's (bad wear, bad wet, very noisy)and mxv4+'s (mad $$, bad dry, bad wet), why o' why are they oem??? Schiesty scheme
Old Dec 14, 2001 | 08:47 AM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
Default Re: dc headers...4-2-1 or 4-1 for a 94 gsr which one is more prefered (KANJI)
But fact of the matter is, you may not hit the track even if you do get cams/gears/VAFC, so 4-2-1 may still be the option even if you increase power down the road if you prefer low-to-mid range power. More advanced setups also help for low-to-mid and so would a 4-2-1 with higher end mods if that's what you're trying to achieve.
Old Dec 14, 2001 | 09:29 AM
dynamite C1's Avatar
hopefully you wont go Turbo soon cuz ur Header will just be replaced by a Turbo Manifold I know my DC 4-2-1 will be gone next summer
atmosphere
11
Apr 12, 2006 03:53 PM
Integgin
Feb 14, 2005 12:15 PM
jt-sport
Aug 26, 2003 03:57 PM
OneFastGsr
Jun 17, 2003 10:27 PM
CaMiKaZi
Jun 14, 2003 05:23 PM
