idol funny
Old Oct 3, 2004 | 10:19 PM
light_racer's Avatar
Default idol funny
i have swap my d16z6 motor into a new d16z6 engine and now its idoling funny.
its going from 1rpm to 2rpm and jumping around... try everything still the same anyone have a idea i could try. could it be my timing.
Old Oct 3, 2004 | 10:56 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: idol funny (light_racer)
American Idol or Billy Idol?
Old Oct 4, 2004 | 08:57 AM
tegmech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by light_racer &raquo;</TD></TR><TR><TD CLASS="quote">i have swap my d16z6 motor into a new d16z6 engine and now its idoling funny.
its going from 1rpm to 2rpm and jumping around... try everything still the same anyone have a idea i could try. could it be my timing. </TD></TR></TABLE>
1rpm. and its running??? You are <U>my</U> idol.
Old Oct 4, 2004 | 09:02 AM
tegmech's Avatar
alright alright, il get somewhat serious. Check your vac lines. Everyone of them. Probably forgot one somewhere.
Old Oct 4, 2004 | 11:27 AM
Default Re: (tegmech)
which is the vac line and which is the water line..........i cant tell which from which...
Old Oct 4, 2004 | 11:40 AM
xcivic_ex
Guest
Posts: n/a
Default Re: (light_racer)
d00d check your spark plug fluid capacitor.. it might be low
Old Oct 4, 2004 | 11:43 AM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (xcivic_ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcivic_ex &raquo;</TD></TR><TR><TD CLASS="quote">d00d check your spark plug fluid capacitor.. it might be low </TD></TR></TABLE>
thats how i blew my old single cam, or was it the 17lbs of boost i was feeding it?
xcivic_ex
Guest
Posts: n/a
Default Re: (turtlecx92)
um no I think it was because you were running the wrong kind of head gasket lubricant
Old Oct 4, 2004 | 11:45 AM
Cain Marko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcivic_ex &raquo;</TD></TR><TR><TD CLASS="quote">um no I think it was because you were running the wrong kind of head gasket lubricant</TD></TR></TABLE>
dont rub it in, mistakes happen
Old Oct 4, 2004 | 11:54 AM
xcivic_ex
Guest
Posts: n/a
hey whats the abc button when you type in a reply?.. it has a blue check on it too.. ohh yea spell check hah
Old Oct 4, 2004 | 12:01 PM
Cain Marko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcivic_ex &raquo;</TD></TR><TR><TD CLASS="quote">hey whats the abc button when you type in a reply?.. it has a blue check on it too.. ohh yea spell check hah</TD></TR></TABLE>
Old Oct 4, 2004 | 01:12 PM
tegmech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by light_racer &raquo;</TD></TR><TR><TD CLASS="quote">which is the vac line and which is the water line..........i cant tell which from which...</TD></TR></TABLE>
you sir, need to take it into a shop and have professionals look at it.
Old Oct 4, 2004 | 01:27 PM
xcivic_ex
Guest
Posts: n/a
disconnect the upper hose that goes to that intercooler type thing.. it'll fix your problems
Old Oct 4, 2004 | 07:34 PM
wat the f is wrong with my car man.........check everything from top of valve cover to the bottom of the oil pan and plus the tip of the header to the back of the fuel fitter..........man.......this **** is annoying me like heck......need help realy bad.......
Old Oct 4, 2004 | 07:39 PM
forgot something.......ok my use to be auto and swap to manual it was running fine untill i blew my motor........and have swap to a 95 si motor which is the same one.....and use my stock automatic harness will that be the cause of my rpm idle funny........will it......huh.........anyone knows..........
Old Oct 5, 2004 | 01:14 AM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by light_racer &raquo;</TD></TR><TR><TD CLASS="quote">wat the f is wrong with my car man.........check everything from top of valve cover to the bottom of the oil pan and plus the tip of the header to the back of the fuel fitter..........man.......this **** is annoying me like heck......need help realy bad.......</TD></TR></TABLE>
are you being serious ?
from trying to understand it sounds like you have a vaccum leak. try spraying tb cleaner around the manifold and throttle body and around any hoses to see if it bogs your motor to see if you have a leak there.
are you getting a check engine light ? could be a problem of the iacv.
try adjusting the idle adjust screw on the throttle body.
what ecu are you running?
you swapped a d16z6 into what car, year ?
Old Oct 5, 2004 | 03:44 AM
xcivic_ex
Guest
Posts: n/a
Default Re: (IVI)
ahhhh hahahahha
Old Oct 5, 2004 | 12:43 PM
Default Re: (IVI)
problem fix. thanks man.... it was my TB gasket. need a new one that it...ehhehehe all this **** for noting.. and it was a 1 bucks gasket need to be replace... this is dump.... on well i fix it...thanks man....oh yah...anyone know what ill need if i swap a b18c1 motor in my car...beside the b18c1 engine, harness, ecu, engine mount, tranny, i got all of that wat else do i need... to i need a engine swap mount or can i use my stock or the gsr mount.. anyone knows...
Old Oct 5, 2004 | 02:38 PM
Cain Marko's Avatar
that runon sentence just gave me a ******* seizure
nekoabandoned
13
Dec 2, 2005 10:05 PM
tca0bell
Apr 27, 2005 09:34 AM
Bukkrog
Sep 13, 2004 06:48 AM
RexLine
Nov 24, 2003 06:02 PM
