Who is running NOS in their R on this board?
Old Dec 13, 2001 | 05:59 PM
AllMotorITR's Avatar
New User
Default Who is running NOS in their R on this board?
I was just wondering if we had any NOS'd out Rs on this board. I was told the other day that cams cannot be used with Nitrous is this true? Where are my NOS'd Rs at?!
Old Dec 13, 2001 | 06:01 PM
Hybrid ctr's Avatar
Default Re: Who is running NOS in their R on this board? (1 FAST R)
IM RealTypeR
Old Dec 13, 2001 | 06:02 PM
sgT's Avatar
sgT
Usually Nitrous buildups are very similar to NA builds.
high compression, high lift cams, etc.
Since there is nothing forcing air into the motor, its more or less the same as
NA except tuning is even MORE critical or else a lot of damage can occur
Old Dec 13, 2001 | 06:07 PM
Stumpy's Avatar
Default Re: Who is running NOS in their R on this board? (sgT)
What is "NA"?
Old Dec 13, 2001 | 06:08 PM
New User
So would NOS work with a Jun 3 setup? Because some guy told me you can't use aftermarket cams with it.
NA = Naturally Aspirated.. a.k.a. All Motor
Old Dec 13, 2001 | 06:27 PM
NighthawkR184's Avatar
You could use Nitrous. It wouldn't matter about your duration or lift on the cam. You would want to retard you timing. Detination is going to be your major concern here. I think that if I were to use nos I would look into a wet system. The hole princeable behind it is to cool the air and make it more denser. The more air fuel that you get into the cylinder the more power you will make. I would not use nitrous myself. I have seen to many guys put a system on and screw there rides up. If you do you need to make sure that you have the fuel requirments met so it doesn't create a lean condition. And N/A stands for natrually aspirated. Nitrous is cheap horsepower until you bend a rod or melt a piston. Just make for damn sure you got it set up right and get your timing were it needs to be. Good luck.
Old Dec 13, 2001 | 07:43 PM
Pinhead's Avatar
New User
Default Re: Who is running NOS in their R on this board? (flamencoR184)
I have 100shot NOS but I hear cams aren't a good thing for nos and plus im fine with the ITR cams....the only other cams I'd get are the crane cams MADE FOR NOS
Icey112
Jun 26, 2005 04:47 PM
BolivianDc2
Aug 24, 2003 08:10 AM
F120man
Oct 31, 2002 05:25 PM
tuco_ruiz
Oct 14, 2002 10:15 AM
