oil cooler?
i've notived two tubes in front of the ac condensor of my gsr. one lopes around on the driver's side while the other runs all the way across the front of the condensor. some kind of cooler i persume(?) because the one that loops around does get kindda warm, but the one that runs across stays cold. what are these tubes (cooler) for?
The 94-95 GSRs came with an oil cooler. The 96-01s did not. The oil cooler is an oil water heater exchanger, so there is no heat exchanger on the front of the car. Like mentioned above, the loop that you see is the power steering cooler.
minvikes
Jul 11, 2011 12:06 PM
