Not building any boost after ITR IM Install
Old Oct 3, 2004 | 10:18 AM
VinceVTEC's Avatar
Default Not building any boost after ITR IM Install
Okay, after my ITR Intake Manifold was installed, I am not building any boost I used a new Hondata IM gasket too. The car idles fine, and i retorqued all bolts and check all vaccumm hoses... tried spraying wd40 b/t the IM and TB, but did not see any differences in idle. What could be wrong??
Also, can copper spray be used on the hondata gasket? Would that be advised?
TIA
Old Oct 3, 2004 | 10:29 AM
Honda_RN's Avatar
Default Re: Not building any boost after ITR IM Install (VinceVTEC)
what do you have SC or turbo?
Old Oct 3, 2004 | 10:32 AM
VinceVTEC's Avatar
Default Re: Not building any boost after ITR IM Install (Ringbearer020)
Turbo... i hear a hissing noise when the motor shuts off... i can't distinguish where its coming from, but the car idles and drives fine... just wont build any boost...
Old Oct 3, 2004 | 10:38 AM
FOrSfEd's Avatar
what kind of vaccum reading do you have at idle
Old Oct 3, 2004 | 10:40 AM
VinceVTEC's Avatar
Default Re: Not building any boost after ITR IM Install (FOrSfEd)
-500 mmHG. I believe it was the same prior to the install also...
Modified by VinceVTEC at 9:06 AM 10/4/2004
Old Oct 3, 2004 | 11:32 AM
VinceVTEC's Avatar
bump
Old Oct 4, 2004 | 05:07 AM
VinceVTEC's Avatar
Default Re: (VinceVTEC)
Could vaccumm hoses that are too long, or have too many tee's attribute to this?
Old Oct 4, 2004 | 05:22 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VinceVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Could vaccumm hoses that are too long, or have too many tee's attribute to this? </TD></TR></TABLE>
Yes.. I am going to say it is a problem with your vac lines. The BOV could be stuck open or even the W/G. Find out wich one it is then go from there. Also check all your intercooler piping for leaks
Old Oct 4, 2004 | 05:35 AM
mattcalica's Avatar
just check everything that you touched while taking off your manifold...retrace your steps...because the car is idling fine, i doubt it would be a vacuum leak and in order for you to not build ANY boost, you would have to have all the vacuum hoses disconnected...maybe the charge pipe that connects to the tb? blowoff valve stuck open? what do you have the boost gauge connected to? does it sound like its boosting? could be a lot of things man...
JDMkidGSR
Mar 15, 2006 08:26 PM
aalb1
10
Apr 19, 2005 07:32 AM
crispydee
Apr 18, 2005 10:21 AM
aalb1
Apr 9, 2005 09:53 AM
GRM Scott
Mar 23, 2004 08:48 AM
