need help on obd2b-obd1 conversion using uberdata
Old Oct 2, 2004 | 10:27 PM
john d
Guest
Posts: n/a
Default need help on obd2b-obd1 conversion using uberdata
set up:
chipped p28/conversion harness/uberdata
so i get ahold of an h22basemap, burn the chip, turn on the car and i get a solid cel. so i get some wire and tried to see what the cel was, but after i jumped it the abs light blinks and not the cel and the code i got off the abs light was 81. but there is no code 81?? i drove on it but it was horrible and bogged real bad. somebody help!
Old Oct 2, 2004 | 10:48 PM
HRTuning's Avatar
Default Re: need help on obd2b-obd1 conversion using uberdata (john d)
You don't go by the ABS light... Solid means you're in limp mode dude... Either you set something up wrong or your soldering job didn't work out too well... Is the chip in the correct way (Notch facing the plugs)? Did you disable the sensors you don't have?
Old Oct 3, 2004 | 08:31 AM
john d
Guest
Posts: n/a
Default Re: need help on obd2b-obd1 conversion using uberdata (HRTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRTuning &raquo;</TD></TR><TR><TD CLASS="quote">You don't go by the ABS light... Solid means you're in limp mode dude... Either you set something up wrong or your soldering job didn't work out too well... Is the chip in the correct way (Notch facing the plugs)? Did you disable the sensors you don't have?</TD></TR></TABLE>
ill try disabling knock like you said, and post some pics later on today. anybody else!?
b18c1vtecdc2
Aug 27, 2008 06:02 PM
typeR564
Feb 26, 2007 10:35 PM
BigChris
Jun 13, 2004 09:42 PM
