Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!!
Old Oct 2, 2004 | 09:07 PM
PYITR821's Avatar
Default Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!!
I have a 99 B18C1 in my 98 Civic hatch, the motor has jdm itr pistons new rod and main bearings new gaskets and everything...the car was running fine until I put my brand new complete ITR head on with ITR IM and mugen head gasket. The motor is loping at idle. I am running the 99 gsr ecu still and I am not sure what is wrong....PLEASE HELP!!!!!
Modified by PYITR821 at 7:51 PM 10/3/2004
Old Oct 2, 2004 | 09:36 PM
eg_type_r93's Avatar
Default Re: Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!! (PYITR821)
check your timing and check your idle rpm
also check for vaccum leaks
Old Oct 2, 2004 | 09:37 PM
PYITR821's Avatar
Default Re: Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!! (eg_type_r93)
timing is fine...no vacum leaks... will turning down the idle stop the loping??
Old Oct 2, 2004 | 09:47 PM
Matty.'s Avatar
I am pretty sure that running the GSR ecu is not a good idea with the ITR IM since its designed a bit differently (no secondaries). Try a different ecu or chip that one.
Old Oct 2, 2004 | 09:59 PM
-=Zeqs=-'s Avatar
Default Re: Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!! (gumtape_deathm
Ya, try running a P73 ECU. As gumtape stated, the maps for the GSR and ITR ecu's need to be different due to the intake manifold. ecu.ff-squad.com maybe Katman might be able to help you out.
Old Oct 2, 2004 | 10:09 PM
PYITR821's Avatar
my idle is at 2100 rpm when I first start it up....which is a little high and it lopes too. Then as the car warms up it continues to lope....could this be from being too lean??
Old Oct 2, 2004 | 10:57 PM
Slow_Em1's Avatar
check timing belt...common mistake. or even something as simple as your firing order on the dizzy.
Old Oct 2, 2004 | 11:44 PM
PYITR821's Avatar
Default Re: Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!! (Slow_Em1)
checked all that....everything is fine.
Old Oct 3, 2004 | 12:07 AM
cheezthis's Avatar
Car should idle fine w/either ECU. GSR ECUs run the skunk2 IM just fine, so it's not that.
I'd double check your valve adjustment and all forms of timing. Also, make sure that if you have adjustable cam gears...that they're set properly. Sometimes they come loose....
Old Oct 3, 2004 | 12:28 AM
Haleiwa-Brando's Avatar
Default Re: (cheezthis)
Wrong...wrong and wrong.
Your getting the 02 sensor code for one reason only. Because of the 02 sensor. I JUST replaced the 02's in my Type R because of the same code.
It is idling high because the code is puting the ecu into a safety mode. I would go as far as guessing that your VTEC isn't engaging? If your throwing an 02 code your VTEC will not engage the car will idle really high, and your torque curve/power will be out the window.
Get the car up in the air. Get under it, look at the wiring going to the 02 Sensor. Look for cuts in the shielding. Take the sensor out and look to see if it's plugged up, slimed up..whatever. If your doubtful about the functionality of the part, throw it out and replace with a new one.
After I did this, my Type R ran fine. I got V-ATTACK back, and my car idled where it was supposed to.
Old Oct 3, 2004 | 03:31 AM
Slow_Em1's Avatar
Default Re: (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Wrong...wrong and wrong.
why?..could be other things. idle screw...hence, diff head. could have bought a diff throttle body that was fucked with. who knows?...02 sensor wont make the idle lope like it has huge cams...it stutters but not lope.
i could be wrong though, let let him find out. Then let him get back to us.
Old Oct 3, 2004 | 10:18 AM
-=Zeqs=-'s Avatar
Maybe the guy forgot to hook up the O2 sensors when everything went back in?
Old Oct 3, 2004 | 01:03 PM
Slow_Em1's Avatar
Default Re: (-=Zeqs=-)
could happen. common mistake to pass something up like that.
Old Oct 3, 2004 | 01:05 PM
PYITR821's Avatar
fixed O2 sensor problem...a wire came loose. Car still lopes though...I unplugged the IAC (the thing on the back of the IM) and alot of the loping stopped..now it just slightly lopes. What can I do now?
Old Oct 3, 2004 | 06:24 PM
PYITR821's Avatar
Default Re: (PYITR821)
Old Oct 3, 2004 | 06:30 PM
kylefakesi-r's Avatar
bleed the coolant. air bubbles in the iac causes lumpy idles.
Old Oct 3, 2004 | 06:37 PM
metal-x's Avatar
Default Re: (kylefakesi-r)
Wich Throtle cable are you using?
could be long shot but the GSR and ITR throtle cables are different
dont think its the ECU because Im running an C1 bottom end with an ITR head and Im using a chipped P28 ecu
Old Oct 3, 2004 | 07:31 PM
PYITR821's Avatar
Default Re: (metal-x)
I am wondering if my headgasket could be leaking?? Do the Mugen headgaskets seal as good as the OEM Honda ones?
Old Oct 3, 2004 | 08:37 PM
-=Zeqs=-'s Avatar
Assuming that you torqued the head bolts down to specs, and the block and head mating surfaces were clean and smooth before you bolted them together, the Mugen head gasket should be just fine.
Old Oct 3, 2004 | 09:22 PM
B_CRUZ!'s Avatar
maybe you accidently switched the plugs for the tps and map. check that.
Old Oct 3, 2004 | 10:24 PM
-=Zeqs=-'s Avatar
Default Re: Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!! (b cruz.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz. &raquo;</TD></TR><TR><TD CLASS="quote">maybe you accidently switched the plugs for the tps and map. check that.</TD></TR></TABLE>
Coming mistake and it is usually the cause for idle to jump from 1000 -&gt; 3000 -&gt; 1000 -&gt; 3000 like it's possessed.
Old Oct 4, 2004 | 02:46 AM
b18c-rDC2's Avatar
Default Re: Just installed a ITR head onto a B18C1 block, now idle is loping....need help!!! (-=Zeqs=-)
or it could be that u just need a new iacv...this is a common problem with bad iacv's
Luchini
Apr 6, 2010 05:12 PM
bleedblue94
Jan 4, 2006 10:05 AM
TylerC
Sep 2, 2005 01:03 PM
daddymaxx
Aug 25, 2003 10:01 PM
daddymaxx
Aug 24, 2003 05:45 PM
