Diagnosis Needed: Broken ring?
Old Oct 2, 2004 | 01:28 PM
dominate9's Avatar
Default Diagnosis Needed: Broken ring?
I busted a balancer shaft bearing in my Prelude. The bearing is right next to the #3 cylinder. When it broke, it took the tip of the oil squirter with it and closed it shut. I have pulled the crank to replace the balancer shaft metal. I inspected the cylinders by pulling the pistons up and down the cylinder by the rods. All the of the pistons are moving up and down smoothly, but the #3 piston is very hard to move and it makes a sucking sound when I try to move it. In fact, I can't puish it all the way towards the head and it springs back when I try. From the bottom of the piston, I don't see any scarring on the cylinder wall. Could I have messed something up or maybe it's like that from the lack of lubricant after the oil squirter broke and just needs some oil? What could be wrong?
Old Oct 3, 2004 | 11:06 AM
dominate9's Avatar
Default Re: Diagnosis Needed: Broken ring? (dominate9)
Anyone?
Jeanious
Oct 28, 2007 03:44 PM
soon2bdropped
Sep 28, 2007 09:43 AM
raiden571
Feb 26, 2007 11:15 AM
dominate9
Oct 13, 2004 06:45 PM
spettinger
12
Jan 27, 2003 12:20 PM
