Why put ATF in your motor?
Old Oct 2, 2004 | 07:14 AM
variablevalve's Avatar
Default Why put ATF in your motor?
Just in general when I read threads about people having to change or adjust parts of the drivetrain, or other things, people always tell them to put ATF in the motor and let it run for a bit. What does putting ATF in with your motor oil do?
yes ive searched...
Old Oct 2, 2004 | 01:00 PM
KiLLa CaM 06's Avatar
Default Re: Why put ATF in your motor? (variablevalve)
to flush out the motor.
Old Oct 2, 2004 | 03:44 PM
perlmeister8's Avatar
The ATF removes all of the condensation that has built up in the motor.
Old Oct 2, 2004 | 10:37 PM
Humble1's Avatar
Default Re: Why put ATF in your motor? (perlmeistere81)
not to be an a$$ but why put atf in a motor when they belong to a tranny. if you need to flush your engine just go to your local auto parts and obtain a engine flush.i think the name of the maker is under gunk products.
Old Oct 3, 2004 | 04:39 AM
b00sted93Hatch's Avatar
Default Re: Why put ATF in your motor? (Humble1)
Your not actually suppost to put it in the motor like oil. You run it through your intake track and into your combustion chamber to clean it out. Disconnect a vacumm line and stick it in the bottle. Rev it to 2k or so and let it run. I've never actually done this so not sure how good it work.
Old Oct 5, 2004 | 01:36 PM
Default Re: Why put ATF in your motor? (allMotor93Hatch)
Yes, you don't drain all of your oil and use atf. You drain a quart of oil and add in a quart of ATF or engine flush. I used this stuff from amsoil
http://www.amsoil.com/products/aef.html
Buzzbomb
29
Apr 15, 2013 03:23 AM
88 EF Hatch
Dec 4, 2008 04:29 AM
4thgenx42
May 5, 2007 09:34 AM
Ruben19
Mar 29, 2006 07:43 AM
98GeeYes-Are
Mar 28, 2002 03:59 PM
