CRV MOROR OR H22
Old Dec 13, 2001 | 09:46 AM
whiteb16a's Avatar
New User
Default CRV MOTOR OR H22
I CURRENTLY HAVE A BI6 IN A 92 HATCH.NOT SATIFIED WITH THE PERFORMANCE .I WANT TO EITHER GET A H22A OR GET A CRV MOTOR AND USE MY B16 HEAD AND TRANNY .MONEY NO PROBLEM .WHICH ONE DO YOU GUYS THINK WOULD BE FASTER .I DO PLAN TO TURBO LATER ,...THANKS ,..
[Modified by whiteb16a, 6:47 PM 12/13/2001]
[Modified by whiteb16a, 10:55 PM 12/13/2001]
Old Dec 13, 2001 | 09:58 AM
Spade's Avatar
Default Re: CRV MOTOR OR H22 (whiteb16a)
B20 fits and good torque....plus you can always go with your B16 head.
Old Dec 13, 2001 | 10:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: CRV MOTOR OR H22 (Spade)
Why are you YELLING? Hehe...
If you plan on going turbo later then KEEP your B16 block. MUCH better rod ratio than the B20.
"What does that mean?"
It means that there is LESS stress on the sides of you cylinder walls because the stroke is shorter. Boost and shorter stroke will get along nicely. The B20 long-stroke causes the pistons to push harder on the cylinder walls - not as good for boost.
Just get some strong forged pistons and forged rods for your B16A and you would be better boosting that way.
For now? Not a whole lot you can do until you boost - what's good for all-motor isn't always good for boost. Good high lift, high duration cams will be good now, but might have too much overlap for boost - boost might actually blow by through the overlap.
My 2 cents.
[Modified by B18C5-EH3, 7:30 PM 12/13/2001]
Old Dec 13, 2001 | 10:40 AM
WICKED2's Avatar
New User
Default Re: CRV MOTOR OR H22 (B18C5-EH3)
get the h22 just need the mount and that its
b20 yeah it will fit perfectly but once u change the head Dude make sure that you change your piston and rod. People say that you can use your stock piston...don't
listen to them its all bs
Old Dec 13, 2001 | 10:45 AM
Spade's Avatar
Default Re: CRV MOTOR OR H22 (WICKEDII)
Wicked, read.... http://www.crvtec.com The B16 head is perfect and sure there is a valve clearence issue however all you have to do is make the valve dents bigger on the stock pistons.....simple.
Old Dec 13, 2001 | 12:43 PM
WICKED2's Avatar
New User
valve clearence is a big isue on some people with a low $.....yeah u can use all dat **** (stock partst) on the b20 but when u go racing (high rpm) just make sure dat u don't mis gear. or u can say bye bye to u'r piston and valve and hello credit card.
for low income pip's i don't rcmd puting a b20 unless u'r going stock on it, but if u'r doing a vtec changes over i don't rcmd it. good luck
[Modified by WICKEDII, 9:45 PM 12/13/2001]
[Modified by WICKEDII, 9:57 PM 12/13/2001]
Old Dec 13, 2001 | 01:54 PM
whiteb16a's Avatar
New User
what about the h22a anybody got one out there eg or ek ?im really thinking about h22 ,because i dont really feel like puting together the crv-vtec thing .what im building is for daliy driver purposes .is the crv-vtec safer after you put it together ,over the h22 that comes complete with torque and vtec built from the factory??just asking
Old Dec 13, 2001 | 02:26 PM
Spade's Avatar
For a daily driver you need to do the B20 IMO the H22 is 100 lbs heavier....and you will lose out on handling braking and ride quality with all of that weight in front!
The CRVTEC's can be reliable if you take your time and do things right and the swaps cost the same roughly.
Honestly read up on both before you decide and the crvtec website answers A LOT of questions.
[Modified by Spade, 3:27 PM 12/13/2001]
Old Dec 13, 2001 | 08:49 PM
brian g's Avatar
First off the engine is only about 75lbs heavier than the B18C.
As for handling, with the right springs it handles better than stock. I road raced one and it handled comparably to my B16 powered 89 hatch. The car I am talking about was the one in Sport Compact Car about 6 months ago with the H22A swap. We had Progress Group send us some springs and shocks and the car handled great. It was as fast as a couple of M3s that were in the same race group.
brian g http://www.hasport.com
Old Dec 13, 2001 | 09:07 PM
kranked91dx's Avatar
Default Re: CRV MOTOR OR H22 (brian g)
I have heard about a shop doing a prelude swap named Atomi'c performance, or Atomi'c racing, swap is very clean and look stock.
If cash isn't a troubble (wish I can be like that some day) go with H22, then turbo charge it lather, it can be a great sources of power, But A b16 can give lot to if it was well dressed!!!
found the site http://www.atomicperformance.com
[Modified by kranked91dx, 6:09 AM 12/14/2001]
Old Dec 14, 2001 | 05:38 AM
WICKED2's Avatar
New User
Default Re: CRV MOTOR OR H22 (kranked91dx)
Ooh boy AtomicPerformance
if u have $ to waste go ahead let them do the work its just (4500-5000 ITS NOT DAT MUCH RITE)....i'm telling u now putting a h22 on a civic or integra (95-95) its not that hard. i have two car 1 crx si w/ h22 my race car 93 civic si w/ h22 dis is my daily ride from work to school.if u guys need help on swapping a h22 email up.
for low $ dis is how u do the swap
h22 complete for only $2300
motor mount for $650 hasport
mugen chip ecu for $ 125
total of $3075
PLS. DON'T LET A SHOP DO THE SWAP FOR U ITS NOT DAT HARd
RadekSkylark
Jul 19, 2010 06:15 AM
arazeg6
Oct 7, 2008 12:34 PM
goldfish123
Jan 16, 2007 09:07 PM
RACEPAK
Apr 16, 2006 05:27 PM
blind
Jul 20, 2001 11:50 AM
