Found sleeve cracks - HELP!
Old Oct 1, 2004 | 05:13 PM
Boofster's Avatar
Default Found sleeve cracks - HELP!
I am changing the headgasket and I looked closer and found this:
first two are 3rd cyl and last is 2nd cyl....
Damn it!!!
Is it ok to put it back together like this or am I royally screwed? How do you go by fixing this? Is the block gone?
Old Oct 1, 2004 | 05:16 PM
johnzm's Avatar
Default Re: Found sleeve cracks - HELP! (Boofster)
thats probably the reason you changed the headgasket in the first place!
those sleeves are toast. sure u can throw it back together and risk some major damage very soon or be happy u caught it before it tore up the head,pistons ect.
sleeving the block is the only way to fix it
Old Oct 1, 2004 | 05:26 PM
dr_latino999's Avatar
Default Re: Found sleeve cracks - HELP! (johnzm)
R.I.P. poor turboed block, time to rip out the sleeves and put new ones, or get a new block.
Old Oct 1, 2004 | 05:27 PM
Boofster's Avatar
Default Re: Found sleeve cracks - HELP! (dr_latino999)
This is so sad. I had it perfectly tuned on the safe side with Hondata and only running at 10psi. WTF!??
Old Oct 1, 2004 | 05:35 PM
It could have been impurities in the actual construction of the block, nothing you could have done to stop it. That is why some last forever under huge loads, and others crack under the wee bittyist of stress.
Old Oct 1, 2004 | 09:47 PM
sloweg6's Avatar
throw in some benson sleeves...
Old Oct 1, 2004 | 09:56 PM
carbine's Avatar
Default Re: Found sleeve cracks - HELP! (sloweg6)
new sleaves
Old Oct 1, 2004 | 11:43 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweg6 &raquo;</TD></TR><TR><TD CLASS="quote">throw in some benson sleeves... </TD></TR></TABLE>
Old Oct 2, 2004 | 12:05 AM
Boofster's Avatar
Default Re: Found sleeve cracks - HELP! (FredoSP)
Details on Benson? I guess there is no point on bringing it back to stock compression? Might as well redo the pistons, rods, etc.....
That would cost a fortune, especially Benson. Probably buying a new block would work better...
Old Oct 2, 2004 | 01:40 AM
HRTuning's Avatar
Damn bro that sucks... Who tuned your setup?
Old Oct 2, 2004 | 02:17 AM
Full-Race Henry's Avatar
Damn Ivan, that really sucks.
If there is anything that I can do for you or if you need any help with anything, Let me know.
Honestly, There could have been many different reasons why you cracked a sleeve, but the #1 Reason is Tuning.
Old Oct 2, 2004 | 04:53 AM
hondaguyef's Avatar
I felt bad when I saw this and since I am such a nice guy I did some searching for you.
Click this for New sleeves
Old Oct 2, 2004 | 07:46 AM
eyeamvic's Avatar
Default Re: Found sleeve cracks - HELP! (hondaguyef)
If you wanted to, you could just sleeve back to 81mm so you wouldn't have to go with buying new rods/pistons all together. I heard the rule of thumb for boosting that going with 85mm or more on a boosted motor is pushing it. It's been done, but many wouldn't recommend it. Just something to consider.
Old Oct 2, 2004 | 07:53 AM
Used2beAb16's Avatar
Dont buy another block, your just going to risk cracking it again. Take it out and sleeve the block, if u really want to u can have just that hole sleeved but i would do the whole thing.
You can get the sleeveing done for $700 or less if u really try. Then you have the question of what size to sleeve at? If u want to keep the pistons you have then u might as well keep the same size, but while you are at it u might as well go 84mm and get some new pistons.
Hey its only money and time right?
Old Oct 2, 2004 | 09:59 AM
_BEN_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">
Damn it!!!
Is it ok to put it back together like this or am I royally screwed??</TD></TR></TABLE>
LOL maybe if you smear some jb weld on it. Im sorry. I shouldn't be laughing at others misfortune.
I would sleeve it.
I just went to Benson sleeve yesterday and talked to Earl and Dan for about a hour while they checked my friends b18c block that dropped a valve..
Both of them were very nice and straight forward. They now have one of those giant robotic cnc machines that do the machine work for the sleeves too.
Needless to say when I start my build im going there. Here is his sleeve post. https://honda-tech.com/zerothread?id=692320
Old Oct 2, 2004 | 10:54 AM
Darton Sleeves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">I felt bad when I saw this and since I am such a nice guy I did some searching for you.
Click this for New sleeves </TD></TR></TABLE>
Those sleeves will not work due to the crack going all the way through the cylinder. M.I.D. sleeve will solve your problem and save your block.
TravisBiggie
Oct 18, 2013 05:08 AM
IndySporty
Jan 27, 2007 07:36 PM
CivicVX94
Jan 27, 2007 04:59 AM
slug
Jan 21, 2004 10:29 AM
Soon_2b_evil
Aug 8, 2003 06:40 PM
