Gsr Injectors
Old Dec 13, 2001 | 08:26 AM
pregunta's Avatar
Default Gsr Injectors
Is there anyway to tell obdI injectors from obdII injectors by looking at them. I have a set and was wondering which they were. And even still will they work interchangeably. I noticed the plug was different from my b18b wiring harness to the injector plug. But I thought this was because the injector was a for a b18c1 and not a b18b1.
Old Dec 13, 2001 | 09:32 AM
Katman's Avatar
Default Re: Gsr Injectors (pregunta)
the plug on OBD1 injectors, only plug into an OBD1 engine harness and will not plug into an OBD2 injector plug.
OBD1 wire-harness side injector plugs are grey
OBD2 wire-harness side injector plugs are black
all you need to do is compare an OBD1 and OBD2 injector side by side and you'll see the difference.
Old Dec 13, 2001 | 10:49 AM
AutoXsi2000's Avatar
I'm sure there is a way you can hard wire them onto that motor, but that is if they will seat and work properly with that motor.
Old Dec 13, 2001 | 10:54 AM
pregunta's Avatar
Default Re: Gsr Injectors (Katman)
Thanks Katman. So these are obdI. (if they won't fit into an obdII plug)
Old Dec 13, 2001 | 01:22 PM
sgT's Avatar
sgT
Default Re: Gsr Injectors (mano77)
just need to swap the plugs on the harness
littleme13
Jun 18, 2014 06:38 PM
zerovandez
May 28, 2014 09:44 PM
lilo_goki
Feb 12, 2008 03:46 PM
tpdc2
Apr 17, 2007 07:09 AM
Chuckles
Nov 14, 2001 02:22 PM
