wich ctr pistons??
Old Oct 1, 2004 | 12:29 PM
sloweredcivic's Avatar
Default wich ctr pistons??
i was on hmotorsonline and h-t doing some research and confused my self wich pistons are the best for a b16
p30
p73
pct ek9 ctr
i am looking for high copression and it will prolly be a stock bottom end.
Old Oct 1, 2004 | 02:38 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: wich ctr pistons?? (mrspeaker)
pct ones mr speaker is correct
although a bore and ITR pistons woulndn't be shabby
Old Oct 1, 2004 | 04:44 PM
how much would i have to bore to put in the itr pistons? if so would that make my engine a 1.8 or is the stroke on a 1.6 diferent. is it safe to bore that far? would i need a block guard? any ideas on what my c/r would be? and lastly what has to be done to fit them on b16 rods or should i get after market rods to?
Old Oct 1, 2004 | 04:46 PM
dr_latino999's Avatar
Default Re: (sloweredcivic)
No, ITR pistons will fit. The bore is the same across the Bs, minus the B20 and the only difference is the stroke.
Old Oct 1, 2004 | 04:56 PM
Steemo's Avatar
Default Re: (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">No, ITR pistons will fit. The bore is the same across the Bs, minus the B20 and the only difference is the stroke.</TD></TR></TABLE>
Old Oct 1, 2004 | 10:44 PM
any ideas on the compression ratio?
Old Oct 2, 2004 | 12:06 AM
Mr_CRX's Avatar
http://www.c-speedracing.com/h...c.php
Old Oct 2, 2004 | 12:58 AM
ceLtic's Avatar
N/A wh0re!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">p30 pistons are from a b16a sirII and are very similar to the ones u have now..
so you'd be waisting ur $$ buying those..
p73 pistons are from a b18c integra-R which is 1.8 liter so they wont fit anyway without getting an overbore done..
The EK9 pct pistons are the ones u want..they come from a civic type-r(b16b)
not true, all b-series pistons WITH THE EXCEPTION OF B20 are 81mm stock bore.
b20 is larger.
Old Oct 2, 2004 | 01:09 AM
civtegra_hybrid's Avatar
the bore is the same on the pistons 81 mm for both b16b18, same bore. that's why you can drop in CTR pistions in a gsr with no prob. and visa versa.
Old Oct 2, 2004 | 01:11 AM
get the CTR's, they better then the ITR any time of the day, there 11.? to 1, unlike the ItR'S 10 TO ONE
Old Oct 2, 2004 | 11:49 AM
thanks alot
dc4b20
Dec 22, 2007 06:57 PM
ekVtecPower
10
Jun 9, 2006 02:15 PM
mrDFWmechanic
Aug 1, 2005 10:32 PM
greasemonkeys
Jan 7, 2005 06:41 PM
TypeR0wnz
Feb 15, 2003 03:06 PM
