no cel at all help
Old Oct 1, 2004 | 08:48 AM
troubledsol03's Avatar
Default no cel at all help
Ok I just recently finished my new all auto meter dash gauges looks great BUT everything works execpt the cel tryed hooking factory gauges back up doesnt work there either now not sure what it is
It is not a bulb tryed that could it be something fryed in the ecu or a blown fuse
Any help would be great thanks
Dustin
Old Oct 1, 2004 | 08:51 AM
Luserkid's Avatar
Default Re: no cel at all help (troubledsol03)
What happened?
Old Oct 1, 2004 | 08:53 AM
no idea unhooked stock gauge cluster wired in new cluster now no cel car runs fine just no cel
Old Oct 1, 2004 | 08:54 AM
Luserkid's Avatar
Default Re: (troubledsol03)
Did you have a CEL before?
Old Oct 1, 2004 | 08:55 AM
mattssi's Avatar
was there one before or something?
Old Oct 1, 2004 | 09:00 AM
yes on start up it should come on then go off now I have nothing at all I did before it would flash once then go out
Old Oct 1, 2004 | 09:03 AM
Luserkid's Avatar
I dont get what you did that would stop the CEL from coming on. Did you put a different gauge cluster in there, did you put indiglos in, what exactly did you do? You are being very vague.
Old Oct 1, 2004 | 09:05 AM
I replaced every gauge with an auto meter gauge tach speedo fuel level coolant temp and used LEDs for all the indicator lights everything is attached to a peice of carbon fiber and installed in the factory location
Old Oct 1, 2004 | 09:08 AM
Luserkid's Avatar
Did you disconnect the batt. before you started doing all this?
Check the bulb. If everything else is working then i doubt its a fuse. Do you have pics of this?
Old Oct 1, 2004 | 09:20 AM
Yes I just took some how do I post them
My ground was disconnected and I have checked the bulb
Stangracer85
Dec 11, 2010 06:12 AM
SOHC_civic_si
19
Jun 1, 2008 10:20 AM
brockscivic
Oct 5, 2005 10:47 AM
