16x7.5" 45 Offset Kosei K1 Fitment?
Old Sep 30, 2004 | 07:12 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default 16x7.5" 45 Offset Kosei K1 Fitment?
I have a chance to get a set of Kosei's and I have a few questions? Will I have any rubbing with this 16x7.5" 45 Offset Kosei K1 Fitment (especially since I am going to be using a 7.5" wide tire and my car is lowered at least 2.25")? Also will I need to use wheel spacers to accomodate the wheels? Thanks!
Old Sep 30, 2004 | 07:32 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 16x7.5" 45 Offset Kosei K1 Fitment? (FrostyDC4)
If they fit it's going to be close. You definitely do NOT want spacers as that would make the offset lower, pushing the wheels further out and making them scrape the fenders.
205/45 tires will work fine on those, should handle awesome.
Old Sep 30, 2004 | 07:37 PM
.water's Avatar
nah..not really good idea..ur car is too low..if drive slow on trun ...no problem..but if ur little crazy driver..big problem.
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: 16x7.5" 45 Offset Kosei K1 Fitment? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">If they fit it's going to be close. </TD></TR></TABLE>
This is what I am afraid of since my car is lowered at least 2.25". I was planning on using these as my DD wheels.
Old Oct 1, 2004 | 09:29 AM
Community Builder
You could probably roll the fenders a bit and be fine.
You would also have to watch tire-to-suspension clearance. 45 offset is the same as the stock 6" wheels right? That means the edges of the wheel extend both outward AND inward an extra 3/4" compared to stock. It's possible that you might actually need a spacer to keep it off the suspension, but then you would have to roll the fenders even more to them from scraping out there.
Old Oct 1, 2004 | 05:40 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">You could probably roll the fenders a bit and be fine.
You would also have to watch tire-to-suspension clearance. 45 offset is the same as the stock 6" wheels right? That means the edges of the wheel extend both outward AND inward an extra 3/4" compared to stock. It's possible that you might actually need a spacer to keep it off the suspension, but then you would have to roll the fenders even more to them from scraping out there.</TD></TR></TABLE>
I'm pretty sure the offset on the stock wheels are 45. This is exactly what I am thinking. Now that I think about it they are not worth it anymore. Thanks for the help
thisguyhere
Honda Civic (2001 - 2005)
16
Jun 11, 2009 08:15 AM
yoorang
Mar 29, 2008 07:53 AM
grey_ghost
Jan 21, 2008 08:57 AM
elitesi8
Jul 13, 2006 12:47 PM
doubledown
May 21, 2003 09:47 PM
