how do you test the ohm on an injector???
Old Sep 30, 2004 | 11:34 AM
racekar's Avatar
Default how do you test the ohm on an injector???
can someone explain this procedure.
i have an ohm meter.
thanks
Old Oct 6, 2004 | 06:43 AM
IN VTEC's Avatar
Default Re: how do you test the ohm on an injector??? (dchung1)
I've got an auto-ranging multimeter, so you may need to select the proper denomination or be able to do the conversion in your head to get the right number.
This is a MSD SCI injector. RC Engineering saturated injectors are 16ohm, at least the older ones are. Newer ones are now 12ohm. I think OEM Honda saturated injectors are around 11 to 12ohms...it's been awhile and I don't have any left.
Keith Pierson's bitch
Oct 16, 2005 09:26 AM
SPOOLINmatt
Jun 15, 2005 09:35 PM
gsrboost
May 26, 2005 06:34 AM
rtpassini
Nov 16, 2004 07:40 PM
BLKCRX
May 25, 2003 07:43 PM
