squeeky clutch
Old Sep 30, 2004 | 08:29 AM
sniffthese's Avatar
Default squeeky clutch
This started a little while ago and i dont know what it is and its annoying as hell..For some reason my clutch squeeks when puching it down to shift but only when the car is cold but it takes a little after when it is warm to go away..This just started not to long ago..what the hell could it be
Old Sep 30, 2004 | 08:42 AM
H22Si's Avatar
Default Re: squeeky clutch (sniffthese)
check your clutch slave cylinder and make sure it's still greased well. where the ball contacts the clutch fork.
Old Sep 30, 2004 | 08:47 AM
kellyk75's Avatar
Throw out bearing!!!
Old Sep 30, 2004 | 08:54 AM
H22Si's Avatar
Default Re: squeeky clutch (H22Si)
does it stop squeaking if you push in the clutch?
Old Sep 30, 2004 | 08:56 AM
sniffthese's Avatar
When i puch in it squeeks until its down then on the way back up no noise...but then it goes away after awile and doesnt happen til lthe next day
Old Sep 30, 2004 | 09:33 AM
VisPreludeVtec's Avatar
i have this same problem, just got my clutch in like 800 miles ago
Old Sep 30, 2004 | 09:47 AM
Eucalyptus lude's Avatar
Default Re: squeeky clutch (VisPreludeVtec)
Yea, I got the same issue. My friend visually pinpointed the problem to a harmonica looking thing near my transmission. Sorry for not knowing the name, but I am new to transmissions.
Old Sep 30, 2004 | 12:19 PM
mike3's Avatar
Check your clutch master cylinder
Old Sep 30, 2004 | 12:45 PM
Default Re: (mike3)
my master cyl was replaced 15k ago
Old Sep 30, 2004 | 03:30 PM
dkny_stylez's Avatar
its common with standard cars, just grease it
Old Sep 30, 2004 | 04:37 PM
midnightaccord's Avatar
Default Re: (dkny_stylez)
yeah were gonna take a look at it friday, grease it and well let you know if we fix the problem!!
Old Sep 30, 2004 | 08:28 PM
4thGenReady2Go's Avatar
Default Re: (midnightaccord)
squeak most noticeable in the cabin? It could also be the spring(s) in the pedal assembly, just lubricate them with grease, especially at any point where they connect or meet another part.
Old Sep 30, 2004 | 11:08 PM
shiftyperformance's Avatar
It is where your clutch release fork meets the pivot ball inside the transmission bell housing. IF you pull back the boot on the outside, look inside where the fork pivots. Try brushing on some high pressure grease, and if you can't reach it, spray in some spray grease making sure to keep it off of your actual clutch. This is definitely your problem.
92_luder
Dec 15, 2010 10:35 AM
OUTKAST1779
Jul 18, 2009 11:19 PM
majinx4
Jun 15, 2006 11:30 AM
jdmteg95
Dec 17, 2002 03:52 AM
awall
Jun 2, 2002 02:45 PM
