Zex 95300/105300 cam valve lash question
Old Sep 30, 2004 | 07:01 AM
Pfieff's Avatar
Default Zex 95300/105300 cam valve lash question
I installed my y8 head the other night with my zex 105300 cam in it and did a valve adjustment. I did it to factory specs of .20mm intake, .25mm exhuast and the valvetrain is louder than hell. I have full ferrea valvetrain. I was wondering what you guys have your valve lash set at with this cam and if it is loud as well. Thanks,
Pfieff
Modified by Pfieffdog at 2:40 PM 9/30/2004
Old Sep 30, 2004 | 07:27 AM
ladysman's Avatar
Default Re: Zex 95300/105300 cam valve lash question (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">I installed my y8 head the other night with my zex 105300 cam in it and did a valve adjustment. I did it to factory specs of .20 intake, .25 exhuast and the valvetrain is louder than hell. I have full ferrea valvetrain. I was wondering what you guys have your valve lash set at with this cam and if it is loud as well. Thanks,
Pfieff</TD></TR></TABLE>
It is loud because you have WAY too loose of settings. Should be .006 and .008.
Edit:
Where the hell did you get those settings at? Did you read the instruction book before installing? (Sorry, had to ask)
Modified by ladysman at 10:38 AM 9/30/2004
Old Sep 30, 2004 | 08:47 AM
Pfieff's Avatar
I just went with OEM valve lash settings, thats what it says right on the hood.
Old Sep 30, 2004 | 09:21 AM
ladysman's Avatar
Default Re: (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog &raquo;</TD></TR><TR><TD CLASS="quote">I just went with OEM valve lash settings, thats what it says right on the hood.</TD></TR></TABLE>
Are you sure that is what it says? .20 big.
Old Sep 30, 2004 | 09:29 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (ladysman)
For a D16Y8, it's .007" I / .009" E right?
Old Sep 30, 2004 | 09:32 AM
omahaturbocivic's Avatar
Yea thats huge. If I remeber right the range is .008-.011 exhaust and .006-.009 intake. I always use around .006 and .008 but I thought I remeber some of the aftermarket cams need them a few thousanths looser.
Old Sep 30, 2004 | 10:06 AM
ELSpool's Avatar
Even at .007/.009 my car still sounds like a diesel.
Old Sep 30, 2004 | 10:07 AM
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">Even at .007/.009 my car still sounds like a diesel. </TD></TR></TABLE>
I have the same problem.
What clearance should I run then? Tighter?
(completely stock rebuilt head)
Old Sep 30, 2004 | 10:09 AM
ELSpool's Avatar
I wouldn't go tighter, I've heard a few D's with this cam, stock heads to fully built ones, all sound the same.
Old Sep 30, 2004 | 10:40 AM
Pfieff's Avatar
I realize that I put my first post in millimeters and you guys are posting in inches. If you do the conversion, I'm right on where you guys are. Guess they are just going to be loud.
Old Sep 30, 2004 | 01:09 PM
Pfieff's Avatar
So i'm guessing everyone is at the recommending value?
Old Sep 30, 2004 | 02:33 PM
RyanEJ8's Avatar
I think I read somewhere that it has something to do with the lost motion assemblies.
Old Sep 30, 2004 | 05:13 PM
ladysman's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I think I read somewhere that it has something to do with the lost motion assemblies.</TD></TR></TABLE>
It is.
.006 & .008
Old Oct 19, 2004 | 08:40 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
It is.
.006 & .008</TD></TR></TABLE>
Back from the dead, sorry.
I'm at 0.006 intake/0.008 exhaust and it's pretty loud to me. Can I get away with the exhaust a little tighter? Say, 0.006-0.007? Or what would happen if it's too tight?
Old Jan 17, 2008 | 04:22 PM
MeanGreenMachine's Avatar
Default Re: (Finest)
bump.
are any of you guys having problems with this cam? like the lobes being all pitted up and stuff?
Old Jan 21, 2009 | 12:14 PM
97-Civic-Ex's Avatar
http://www.turbod16.com/viewtopic.php?f=26&t=40380
Fighterinsnatch
16
Jul 26, 2007 08:02 AM
hatchedzex
Mar 22, 2006 04:46 PM
mixmastabob
Jan 23, 2005 05:38 PM
CrXr89Si
Feb 17, 2004 11:14 PM
