tech question about injectors
Old Sep 29, 2004 | 11:38 PM
racekar's Avatar
Default tech question about injectors
on my swap i have a b16 with ITR manifold and it has gsr fuel rail i think with prelude injectors. but my friend tells me that the prelude injectors need a resistor to work and the b16 doesnt have one? is that right? How would i identify if its a prelude injector any special markings?
thanks
here is a bad pic of the injector i have what car injector is this?
http://www.imagestation.com/pi...8.jpg
it has 4 yellow dots on side
i have a 1994 civic cx
i did some more research and i think i can use 97-2001 lude injectors on my car without resistor box is this correct?? would my car not start if i didnt have the resistor box.. what would happen if i ran the car without resistor box if these were previuos generation prelude injectors?
Modified by dchung1 at 1:11 AM 9/30/2004
Modified by dchung1 at 1:28 AM 9/30/2004
Modified by dchung1 at 1:56 AM 9/30/2004
Old Sep 30, 2004 | 12:11 AM
racekar's Avatar
do i need a resistor box???
Old Sep 30, 2004 | 12:37 AM
racekar's Avatar
need help desperately thanks
Old Sep 30, 2004 | 05:46 AM
racekar's Avatar
anyone, my car starts and runs with the injectors just very rich... if i had the wrong prelude injectors in there would it start and run??? i bought this swap so im not sure what the exact specs are
Old Sep 30, 2004 | 08:38 AM
HT Chaplain's Avatar
Loved
Default Re: tech question about injectors (dchung1)
depend on what year the injectors are if theyre OBD 0 then ther need a resistor box
Old Sep 30, 2004 | 09:49 AM
racekar's Avatar
will my car run if they were older prelude inje?? i heard that 97-2001 inj are ok to run without resister? my car runs without the resistor box and i dont know what year the injecotrs are... so im just trying to figure out if it will run if i have previous year generation prelude injectors or will the car not start up???? becasue it starts and runs ok.
Old Sep 30, 2004 | 11:42 AM
racekar's Avatar
rc engineering said that i would be able to use pre 97 lude injectors but it would make my ecu run hot.. withou resistor box..
but the 5th gen lude injectors would be fine without reisistor box. i dont think i have the 5th gen injectors though.
Old Sep 30, 2004 | 12:59 PM
H22coupe's Avatar
Default Re: (dchung1)
get an ohmmeter and check resistance of an injector. If it's like 6 ohms you need a resistor pack. If it's around 16 ohms you're fine (I forget the exact values but I know that's close as the resistor pack is a 10 ohm resistance)
running the low resistance injectors without the resistor pack can fry your ecu
Old Sep 30, 2004 | 03:07 PM
racekar's Avatar
yeah rc eng said higher than 11 is okk, 2-3 means you need a resistor box. ohms that is
how do i check ohms using an ohm meter never used one
CivSiClone_96
Dec 20, 2009 05:52 PM
PTVDesign
Aug 30, 2009 07:40 AM
caliprelude3087
Sep 6, 2004 05:39 PM
thehondaguru
Feb 14, 2004 04:32 AM
