install apexi sohc kit on my b18b :)
Old Sep 29, 2004 | 11:13 PM
egturbo's Avatar
Default installed apexi sohc kit on my b18b :)
WHERE SHOULD I SET MY TIMING AT? my car kinda bogging from 1k-2k rpms
well this install only took 5 hours and the modifiying only took about 1.5-2 hours.
dude this thing spools at 2.5-3k haha crazy ****.. but u can't hear my car spool up should i run w/ out the intake and filter and just run mess? here are pics of it installed very nice no leaks hahah the best part is i didnt have to buy any extra parts to make it fit.. fits nice w/ no leaks. i just gotta fix my timing..
where should i set my timing at? cuz its lagging right now.. well here are pics. enjoy! thanks glagola for all ur help and charliemoua also for putting up w/ all my ?'s and espcially my friend lim that helped me out alot on my install and everything. i still dont see how u would use the hks b series mani though charlie lol..
should i keep the filter/intake or just put a mess screen on the turbo?
all in all im very satisfied w/ this kit..
Old Sep 30, 2004 | 04:48 AM
VinceVTEC's Avatar
Default Re: installed apexi sohc kit on my b18b :) (egturbo)
looks awesome, i wish i would have picked up the apexi kit for my car instead of greddy b/c of the ball bearing turbo... and the fact that it forces me to get a standalone... looking good! keep the filter!
Old Sep 30, 2004 | 04:52 AM
swlabhot's Avatar
Jeeez, those pics looks like they're from the 50s! Have you not got some fresh n clean ones?
Anyway, I would def put a filter on it, if not at least a mesh before the blades gets shreads to pieces should debris get in there!
Old Sep 30, 2004 | 08:12 AM
egturbo's Avatar
Default Re: installed apexi sohc kit on my b18b :) (swlabhot)
thanks guyz.. i do have a intake/filter on there. just wondering if i use just a mess screen would i get better spool?
Old Sep 30, 2004 | 08:47 AM
RacerXI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo &raquo;</TD></TR><TR><TD CLASS="quote">thanks guyz.. i do have a intake/filter on there. just wondering if i use just a mess screen would i get better spool?</TD></TR></TABLE>
Not sure on spool, but using mesh to get more spool isn't worth destroying the turbo.
Old Sep 30, 2004 | 09:05 AM
glagola1's Avatar
Why don't you turn up the wastegate spring? It'll make about 8psi on that spring... You'll never hear 4psi spool...'cause that ain't sh*t man.
Get a couple 10mm spanners and shorten the wastegate arm by about 2mm and see how much boost you get. I bet you'll see 6psi. Adjust as necessary.
I can't tell you where to set your timing because I have no idea what kind of engine management you are running. Looks like you have no timing control and a fmu for fuel. If that's the case, you should retard your timing about 1* per lb of boost. If you are running 4psi set your timing to 11*btdc to be safe. It's possible your car is running rich down low and that's why it's bogging.
Old Sep 30, 2004 | 10:49 AM
egturbo's Avatar
Default Re: installed apexi sohc kit on my b18b :) (glagola1)
im running fmu/fuel pump/ missing link imma try to turn up the boost today using my profec b i want at least 8-10 psi but damn the fmu disc is only 10:1
oh and the hks bov is it supposed to sound like turbo surge? lol cuz i loosened it and still sounds the same. wait which way is lose and tighten on an hks bov? haha
Old Sep 30, 2004 | 10:52 AM
J337_UNIT's Avatar
leave filter and intake on, mesh screen is not a good idea, only a last resort.
Old Sep 30, 2004 | 11:37 AM
Eskay@JDMCircle.com's Avatar
i want that heat shield!
Old Sep 30, 2004 | 12:06 PM
egturbo's Avatar
Default Re: (skt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skt &raquo;</TD></TR><TR><TD CLASS="quote">i want that heat shield!</TD></TR></TABLE>
haha u like?
Old Sep 30, 2004 | 12:28 PM
Charlie Moua's Avatar
what manifold did you deciede to go with?
looks like a clean job on the turbo install. Glad to see that it's up and running now.
Old Sep 30, 2004 | 01:07 PM
egturbo's Avatar
Default Re: installed apexi sohc kit on my b18b :) (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">what manifold did you deciede to go with?
looks like a clean job on the turbo install. Glad to see that it's up and running now.</TD></TR></TABLE>
ended up using the sohc apexi one haha.. works like a charm but the damn sohc ports are sooo small thanks for all ur guyz help.
Old Sep 30, 2004 | 01:49 PM
Mr.Mugen's Avatar
Keep the filter I've seen too many people with screens or mesh still get crap in there turbo's nothing lamer than ruining a low mileage or great running turbo and jacking it all up because a 25 cent peice of mesh falls off do to street debris or road rock's yike's !!!! As far as the turbo lag problem take it to a shop thats good with turbo application's and have it tuned or fixed sounds like your almost there and have done most of the work that would cost alot .
Old Sep 30, 2004 | 02:21 PM
f22b2tdave's Avatar
Default Re: (Mr.Mugen)
clean *** install man, cough heatwrap insulates cough,
id keep the filter on, but i just threw a few squares of my home ac filter tbolted to the compressor inlet and my t3/t4b sounds like a jetplane whine at 2k with a shitty basemap.
BurlyHatch
Nov 18, 2003 01:36 AM
BurlyHatch
Nov 13, 2003 12:35 PM
BackSideSA
17
Jan 14, 2003 09:53 AM
mantic6t9
Mar 29, 2002 10:45 AM
