header/exhause rattle???
Old Sep 29, 2004 | 06:15 PM
hoehouseworker's Avatar
Default header/exhause rattle???
The other night i installed a high flow cat (Ractive, very cheap ) and ever since then ive had a rattle towards higher rpms. The rattle comes from the cat/ header area but i cant pin point it. Its a 96 si w/ dc header and stock exhaust.
Old Sep 29, 2004 | 06:45 PM
Default Re: header/exhause rattle??? (hoehouseworker)
anybody????
Old Sep 29, 2004 | 07:17 PM
five-0's Avatar
Well if the rattle developed after the cat install, then the culprit is ____________.(Fill in the blank)
Sorry, I couldn't resist. Make sure it's not hitting a heat sheild. Those like to rattle.
Old Sep 29, 2004 | 08:15 PM
AndyD's Avatar
Default Re: header/exhause rattle??? (five-0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by five-0 &raquo;</TD></TR><TR><TD CLASS="quote">
Make sure it's not hitting a heat sheild. Those like to rattle. </TD></TR></TABLE>
I agree.
Also, make sure that the bracket that mounts the header to the block is secure tightly and check to make sure it isn't cracked.
Old Sep 29, 2004 | 08:31 PM
Default Re: header/exhause rattle??? (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Also, make sure that the bracket that mounts the header to the block is secure tightly and check to make sure it isn't cracked.</TD></TR></TABLE>
Header is good, and i took off the heat sheilds b/c there was no holes to secure them. any other suggestions?
bliss@5200
Apr 7, 2006 10:42 PM
o2flow.net
11
Jan 27, 2006 12:21 PM
enhancedCL9
Oct 5, 2005 02:57 AM
1995H23Lude
Nov 30, 2004 10:11 AM
slowacura
Nov 13, 2004 04:56 PM
