whats wrong with my clutch?
Old Sep 29, 2004 | 05:16 PM
00000xxx's Avatar
Default whats wrong with my clutch?
i think i need a new clutch let me describe whats going on...i can get into first gear (but the pedal feels soft not like it did a few days ago) then after that the clutch is useless i have to powershift the rest of the time. when i first use the clutch before its warmed up theclutch chatters. i replaced the clutch slave cylinder, replaced the clutch line with a steel braided line, and bleed the line. does what i just described sound like the clutch or pressure plate or could it be something else???
1998 B16b lsd tranny
Modified by ctr610 at 6:51 PM 9/29/2004
Old Sep 29, 2004 | 07:29 PM
ViZ's Avatar
ViZ
Default Re: whats wrong with my clutch? (ctr610)
sounds to me like the pressure plate, i would suggest to double check your fluid level but you bled the lines and so im assuming its ok.. i would say its either the pressure plate or the clutch fork. Also does your car seam to pull or stutter when you hold the clutch in? sort of like your not pushing the clutch down all the way. And one more thing to inspect is the springs in the clutch but either way i think you are going to have to drop the tranny and check it out because that seams to be where the problem is.. good time for an upgrade though, thats what i did
Old Sep 29, 2004 | 07:46 PM
00000xxx's Avatar
Default Re: whats wrong with my clutch? (ViZ)
thanks, i pushed the pedal all the way to the floor and the clutch only stutters when i'm getting to first i thought it was the clutch right off the bat im gunna drop the tranny this weekend then see what the deal is prolly throw a ACT clutch and flywheel up in that joint
redline7
Feb 23, 2008 08:53 PM
InitialJRift
Sep 13, 2006 10:43 AM
FK00GSR
Mar 31, 2005 06:55 AM
Simple
Sep 17, 2004 11:16 PM
PetroGuyX
Jun 21, 2003 06:24 PM
