idle vibration. Engine mounts?
Old Sep 29, 2004 | 03:01 PM
typhoon's Avatar
Default idle vibration. Engine mounts?
When my 4th gen is warmed up and idling low (600-800 RPM) I feel a vibration though the car. I'm wondering if that means the engine mounts are looser than they should be.
If that could be it, How expensive is that to fix?
Old Jan 6, 2005 | 09:34 PM
Shehzada's Avatar
Default Re: idle vibration. Engine mounts? (typhoon)
They are not looser....but if you look closely you will notice the rubber torn.
What I would do if I were you is order the Torque Rod and install it. But first check and make sure that the rubber is torn and indeed bad. I am getting some vibration too and my rod is totally shot. I can't wait to install the new one once I get it.
genetsang
Sep 30, 2023 05:15 PM
raverx3m
Jan 6, 2016 08:32 PM
zumiez007
Jul 10, 2009 12:13 AM
SoullessJapaneseMachine
Jul 31, 2008 09:43 AM
DeSolMan007
Jun 19, 2003 11:50 AM
