need help on this..
i'm having problem with my 98 gsr, no power at all. i check the cell code and it giving me # 8 and 81. which is tdc sensor and miss firing cyc 1. does this mean my timing is off or something else? or a bad sensor? i just had a new distrubutor install, cap and rotor, new spark plug.
the old owner of the car had that problem, what he did was unplug the ecu and plug it back in. the check engine light would turn off for a week or 2 and come back on again.
i replace it with a aftermarket dist. from kragen. i know i should of went with oem but it was last minute.. i dont think i need a cps, i think i need the tdc senosr.. not sure on that either..
From: im nothing from no where im no one at all, ca
try adjusting the timing. just jump the service connector. (car has to be at operating temperature) turn your car on get the timing light and adjust your timing. also line up your cams and check if the crank pulley is at top dead center.
EF9 JAMS!!!
Aug 8, 2007 10:57 PM
vsual
12
Dec 10, 2001 02:45 PM
