need help on this..
Old Sep 29, 2004 | 11:42 AM
sl33pyelmo's Avatar
Default need help on this..
i'm having problem with my 98 gsr, no power at all. i check the cell code and it giving me # 8 and 81. which is tdc sensor and miss firing cyc 1. does this mean my timing is off or something else? or a bad sensor? i just had a new distrubutor install, cap and rotor, new spark plug.
the old owner of the car had that problem, what he did was unplug the ecu and plug it back in. the check engine light would turn off for a week or 2 and come back on again.
Old Sep 29, 2004 | 05:53 PM
sl33pyelmo's Avatar
Default Re: need help on this.. (sl33pyelmo)
ANY ONE??????
Old Sep 29, 2004 | 07:37 PM
..::91TEG-G2::..'s Avatar
bump for some help on this, i know it can be a pain in the a$$
Old Sep 30, 2004 | 02:39 AM
mr.beeks's Avatar
Default Re: need help on this.. (..::91TEG-G2::..)
did it get replaced with same distributor
if you need a crank poss sensor that also controls this
I have 2 here.
Old Sep 30, 2004 | 10:39 AM
sl33pyelmo's Avatar
Default Re: need help on this.. (mr.beeks)
i replace it with a aftermarket dist. from kragen. i know i should of went with oem but it was last minute.. i dont think i need a cps, i think i need the tdc senosr.. not sure on that either..
Old Sep 30, 2004 | 11:46 AM
tegsallgood's Avatar
bump- help this guy out... i have no idea. that fter makret dist.might be the problem buddy
Old Sep 30, 2004 | 12:15 PM
deviusdragger's Avatar
From: im nothing from no where im no one at all, ca
Default Re: need help on this.. (tegsallgood)
try adjusting the timing. just jump the service connector. (car has to be at operating temperature) turn your car on get the timing light and adjust your timing. also line up your cams and check if the crank pulley is at top dead center.
Old Sep 30, 2004 | 08:49 PM
deepgreengsr's Avatar
Default Re: need help on this.. (deviusdragger)
get oem, that mexico made **** from kragen is crap
eg grom
19
Jun 22, 2009 06:25 PM
EF9 JAMS!!!
Aug 8, 2007 10:57 PM
crnimacak
Mar 20, 2006 10:04 PM
outbrakeridah
Mar 11, 2006 07:27 PM
vsual
12
Dec 10, 2001 02:45 PM
