water leaks
hey all,
I have serious rain leakage leading to water damage. I am growing bitter. So we all know about the window driver & passanger window leaks - they are due to the drying and shrinking of the rubber molding. Now I have a leak under my glove box. Fortunatly it is starting somewhere behind my glove box but they are both driving me up the wall. I go from rainny outside to wet inside.
Any suggestions?
Any suggestions?
The seam between the firewall and the unibody is shitty in our cars and is known to be a huge leak area. You can get to it under the wiper cowl if you'd like to try and fix it by yourself.
My Ek was leaking around the tube that runs trhough the firewall right there to drain out your AC. I ran a bead of silicone around the edge of it and no longer have the problem.
Tutu
17
Sep 23, 2012 06:12 AM
pinks11
Oct 17, 2007 02:34 AM
