Darton-MID-sleeves with original HondaHeadgasket?
I plan to get my B16A2 sleeved with Darton-MID. After that, can I use a original HondaHeadgasket without problems or will I have to take an otherone(cometic for example, like people at Darton told me)?
did you increase the bore size?
if no then u can use the stock head gasket, i
if yes the you will have to buy an aftermarket one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekracer »</TD></TR><TR><TD CLASS="quote">If you sleeved to 84 bore, use a CRV head gasket. If you went bigger than that, use aftermarket.</TD></TR></TABLE>
depends on which block you are using.
Honda Head Gaskets are the way to go. Cometic gaskets arent necesarry. Overbored OEM gaskets will do the job.
just out of curiousity, what if say, u have an open deck, say ummm f22? then u sleeve it withan MID and its closed, do you need to get a closed deck HG?
cuz i think for the h22a1 and a4 the open and closed deck have differnt gaskets?
dravesef
Feb 12, 2008 11:29 AM
h22_crx
Nov 20, 2006 08:31 PM
