B18C1 Rebuild help
Old Sep 29, 2004 | 10:29 AM
JDMVTEC's Avatar
Default B18C1 Rebuild help
I have a 95 GSR with very high mileage 190,000 to be exact and I have these plans to rebuild the enigne and I wanted to ask you all if I was going in the right direction. Note I don't have alot of money to spend. If you have any suggestions please post thanks. Here is what I had in mind
B16 Pistons
B16 Tranny
CTR Intake Cam
Copper Head Gasket
Old Sep 29, 2004 | 01:49 PM
JDMVTEC's Avatar
no suggestions
Old Sep 29, 2004 | 01:54 PM
gen2moredoors's Avatar
Default Re: (JDMVTEC)
why not rebuild to stock? you'd save money. if moneys the issue just buy the rebuild items.
Old Sep 29, 2004 | 02:01 PM
JDMVTEC's Avatar
see I had thought about that but wouldn't this make it faster than just normal rebuild parts and its not going to cost that much more.
Old Sep 29, 2004 | 02:51 PM
JDMVTEC's Avatar
The b16 pistons would raise compression right? Just want know what I should do.
Old Sep 29, 2004 | 04:50 PM
MikeTV
Guest
Posts: n/a
I am in the same boat as you....183,000 miles. I am planning on rebuilding this winter, for boost. If you are gonna spend the money, you might as well rebuild it stronger than it was. Sleeve the block, close the deck, get 9:1 compression piston for turbo, or 12:1 for all motor. get new hoses, fuel pump, water pump, oil pan, vtec solenoid, cams etc. Oh yeah dont forget to port the head.
Jesussaves87
10
Jun 26, 2007 06:45 PM
inzaneN1
Apr 6, 2005 10:51 PM
tRex99
10
Nov 12, 2004 12:16 PM
_jester_
Feb 15, 2004 12:40 PM
