clutch pedal question??
i need to adjust my clutch if that makes any sense? lol i notice that i can push in on the clutch about an inch or so without the clutch engaging. I wanted to see how i could tighten that up a bit so that extra slack or what have you is gone. anyone done this? how can i fix that?
thanks
thanks
There's a lock-nut adjustment on the clutch piston shaft. There's also an adjustable stop for the pedal, if you have cruise it's the clutch switch. If you don't have cruise it's just a funny bolt that the clutch pedal rests against.
Adjust it to proper pedal height & free-play. If you get it all messed up the hydraulic system can't self-adjust as the clutch wears out.
