VSS sensor
Old Sep 28, 2004 | 10:21 PM
UNKNOWN_MEMBER's Avatar
Default VSS sensor
Hey I plan on changing my transmission fluid soon but I don't know where the drain bolt for the tranny is located and I don't know where the VSS is located at. I need pictures....thanks BTW: it's for a b series tranny
Old Sep 29, 2004 | 02:35 PM
bump
Old Sep 29, 2004 | 06:06 PM
hayabusa160's Avatar
Default Re: VSS sensor (UNKNOWN_MEMBER)
its on the tranny look straight down its between the dizzy and tb
Old Sep 29, 2004 | 08:04 PM
Default Re: VSS sensor (hayabusa160)
took a picture of what I see between dizzy and tb.
where's it at?
Old Sep 29, 2004 | 08:43 PM
does the VSS have a rubber cap on it? Then when u remove the cap theres a nut?
Modified by UNKNOWN_MEMBER at 6:20 AM 9/30/2004
Old Sep 29, 2004 | 08:46 PM
SkRiBLaH's Avatar
Default Re: (UNKNOWN_MEMBER)
this is what the VSS looks like.
you'll only see from the long notch in the middle to the left.. the rest would be in the tranny.
there is a plug going to it.
Old Sep 29, 2004 | 09:16 PM
daym dude i can't find it...once you take out the cap is there going to be a nut? cause the one im talking about has a nut after the cap.
Old Sep 29, 2004 | 09:56 PM
is this it?
Old Sep 30, 2004 | 06:55 AM
look from the side passenger fender bend over and look straight down from there
Modified by hayabusa160 at 11:27 AM 9/30/2004
Modified by hayabusa160 at 11:28 AM 9/30/2004
Old Sep 30, 2004 | 06:56 AM
if you take like a rubber cap off and see like a silver nuts that prolly the starter
you gotta look deeper its way down there
here i borrow this pic from tom the admin
Old Sep 30, 2004 | 06:59 AM
zad5's Avatar
u know where ur starter is look at ur starter from the fender and then its a little from the left ull c this black connector. the drain/fill bolts are a little farter down then the speed sensor go to team-integra.net check out the article for tranny fluid. very good article good pictures u cant get confused. i heard of some jiffy lube guy messign up a tranny for takingo tu a bolt that he thought was the drain or fill and messed up the tranny so make sure its the right bolt..
Old Sep 30, 2004 | 09:44 PM
Default Re: (hayabusa160)
no picture..um...i think the vss sensor is covered by the chassis, am I right? So in order to access the vss sensor where do I actually see it? Under the hood or under the car?
Old Sep 30, 2004 | 10:03 PM
JL's Avatar
JL
i'm trying to figure out why you need to know where the vss is to change the transmission fluid? you took a picture of the starter with the rubber cover though.. the vss is that black piece of plastic with a plug on it that is vertical coming out of the back side (still on the top) of the transmission.. there is a picture of it.. this view is going to be from the passengers side fender with the front of the car to your right. and your wheel infront of your legs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
i don't know where you are located but honda dealer or jiffy lube (something similar?) can do it for you.. always a thought.
Old Oct 1, 2004 | 06:32 AM
zad5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">no picture..um...i think the vss sensor is covered by the chassis, am I right? So in order to access the vss sensor where do I actually see it? Under the hood or under the car?</TD></TR></TABLE>
hayabusa160 shows a very good picture look on top of the car over the passenger fender look at the distributor then look to the left of it. ull c the starter look to the left of it ull c the black sensor look at hayabusa pic thats the sensor. draining tranny fluid u go underneath the car trust me check out the article it helps out so much.
dL_EG6
Feb 19, 2007 09:06 AM
aser1z
Sep 7, 2005 08:17 PM
dxhatch92
Mar 23, 2004 11:29 AM
sting94112
Feb 22, 2004 01:38 PM
team2n1hatch
Jun 30, 2003 04:00 PM
