PBR Brake Pads - Always in stock! Unbeatable pricing! From $28.66!!
We carry PBR Deluxe and PBR Metal Master pads.
PBR Deluxe Plus brake pads are perfect if you are looking for an extremely low dust brake pad that is also very quiet and rotor friendly, yet has the grip and fade resistance required for performance cars. These organic pads continue to work well at temperatures up to 716 °F, similar to OEM pads. The only thing you give up is the dust! So stop washing brake dust off your wheels every few days without giving up any braking performance.
PBR Deluxe Brake Pads
PBR Metal Master semi-metallic brake pads excel in high performance, high speed, and high heat circumstances. Plus, depending on your driving style, the life expectancy of PBR Metal Master pads exceeds other conventional semi-metallic pads by 200 to 500 percent. Fade, squeal, and unsightly brake dust have been virtually eliminated. Containing no asbestos, PBR Metal Master pads provide the ultimate in stopping power under all driving conditions - wet or dry.
PBR Metal Master Brake Pads
Want Power Slot Rotors?
Always in stock!!
HardParkedCom
456
Sep 22, 2012 07:38 AM
