doing a swap soon.. got couple questions to ask..
Old Sep 28, 2004 | 08:35 PM
92eh3si's Avatar
Default doing a swap soon.. got couple questions to ask..
i am doing a jdm b18c swap into my 92 eh3..
i was wondering if i can use my stock radiator hoses, use my stock o2 sensor?
help me out here.. i am doin the swap on saturday..
hopefully everything goes smooth and be done!!
oh yea!! one more thing..
do i need a B-series throttle cable and bracket?
Modified by 92eh3si at 7:00 PM 9/29/2004
Old Sep 28, 2004 | 08:52 PM
Luserkid's Avatar
Default Re: doing a swap soon.. got couple questions to ask.. (92eh3si)
I think your going to need new hoses, and a 4 (or is it 5) wire 02 sensor.
Old Sep 28, 2004 | 09:07 PM
Ignitecivic's Avatar
Default Re: doing a swap soon.. got couple questions to ask.. (Luserkid)
its depends on what model is ur hatch. if its a Cx, u do need to convert to a 4 wires o2 sensor, other then that the dx, si are already 4 wires o2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I think your going to need new hoses, and a 4 (or is it 5) wire 02 sensor. </TD></TR></TABLE>
u will need the new hoses cuz ur old one wont reach to the side of the b18c motor.
Old Sep 28, 2004 | 10:33 PM
92eh3si's Avatar
Default Re: doing a swap soon.. got couple questions to ask.. (Ignitecivic)
I have a 92 si..
so new hoses and reuse o2 sensor right?
Old Sep 28, 2004 | 10:44 PM
The Mista Mike's Avatar
o2 sensor was only 5 wire/wideband on the vx and hx
Old Sep 29, 2004 | 10:04 AM
92eh3si's Avatar
throttle cable??
Old Sep 29, 2004 | 10:47 AM
92eh3si's Avatar
Default Re: (92eh3si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92eh3si &raquo;</TD></TR><TR><TD CLASS="quote">throttle cable??</TD></TR></TABLE>
anybody??
Old Sep 29, 2004 | 10:49 AM
dantastic's Avatar
u can re-use your stock throttle cable
Old Sep 29, 2004 | 12:45 PM
92eh3si's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">u can re-use your stock throttle cable</TD></TR></TABLE>
are u sure? i was told that it would be lil short
Old Sep 29, 2004 | 12:59 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: doing a swap soon.. got couple questions to ask.. (Mistamike17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistamike17 &raquo;</TD></TR><TR><TD CLASS="quote">o2 sensor was only 5 wire/wideband on the vx and hx</TD></TR></TABLE>
you're correct. cx doesn't come with a 5 wire.
Old Sep 29, 2004 | 01:00 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: doing a swap soon.. got couple questions to ask.. (AzntaggeR)
use the radiator hose for the gsr motor. your stock hose is a bit smaller.
Old Sep 29, 2004 | 01:14 PM
project_mercy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">
you're correct. cx doesn't come with a 5 wire.</TD></TR></TABLE>
Yes, it comes with a 1-wire. Hence it also won't work
Throttle cable, you can get it to work by taking a flat peice of steel and drilling holes in it to extent the manifold mounting point, or you can spend the $22 and buy a b-series one (Del Sol VTEC, Integra LS, or ITR)
Edit: Didn't notice it was a GSR manifold *bonk* So those throttle cables would also be wrong. See below
Modified by project_mercy at 12:24 PM 10/1/2004
Old Sep 29, 2004 | 01:31 PM
ej1 pilot's Avatar
Default Re: doing a swap soon.. got couple questions to ask.. (project_mercy)
btw vx has 4 wire also
Old Sep 29, 2004 | 01:37 PM
Default Re: doing a swap soon.. got couple questions to ask.. (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion &raquo;</TD></TR><TR><TD CLASS="quote">btw vx has 4 wire also</TD></TR></TABLE>
Mine didn't. Nor has any other vx I've known that had the OEM D15Z1 in it
Old Sep 29, 2004 | 01:53 PM
untitledsn41's Avatar
are u sure? i was told that it would be lil short</TD></TR></TABLE>
no it wont be short. there are a few ways of making it work. i moved the throttle cable bracket to the firwall (took one of the bolts off from the clutch fluid line and mounted the bracket there) and then just put the cable through it and it matched up fine. i will try and get a picture up a little later.
Old Sep 29, 2004 | 07:33 PM
92eh3si's Avatar
Default Re: (untitledsn41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitledsn41 &raquo;</TD></TR><TR><TD CLASS="quote">
no it wont be short. there are a few ways of making it work. i moved the throttle cable bracket to the firwall (took one of the bolts off from the clutch fluid line and mounted the bracket there) and then just put the cable through it and it matched up fine. i will try and get a picture up a little later. </TD></TR></TABLE>
pics will help!! thanks!!
Old Sep 30, 2004 | 09:09 PM
umm, well the pic is kinda low quality but its all i got
the bracket was moved behind the IM, all i did was remove a bolt to the firwall(holding a section of the clutch fluid line up) and place the bracket in its place
Old Oct 1, 2004 | 09:20 AM
92eh3si's Avatar
nice.. aite.. i might do that..
i will post pics up after i get my swap done tomorrow night!!!
Old Oct 1, 2004 | 09:37 AM
Go count em again.
Old Oct 1, 2004 | 02:33 PM
RabbittZ's Avatar
my 95 cx is a 4 wire.....
go for a itr cable. might come in handy later on if a new mani comes in to play? just a suggestion
icedemon
Apr 19, 2006 02:09 PM
daRk kNight
Oct 20, 2005 09:22 AM
dropd4door
10
Dec 27, 2004 06:07 PM
Mr HYDE
Mar 15, 2003 06:10 PM
92CIVICCX
Jul 25, 2002 08:17 AM
