D16Z6 + 14B + Dyno = .......
Old Sep 28, 2004 | 07:33 PM
USDM 4G VTEC's Avatar
Default D16Z6 + 14B + Dyno = ....... Updated, Dyno sheet inside
to make a long story short
did a baseline on the VAFC Hack
I tried to tune my car with Turbo Edit, but the ECU kept redlining at 4k with no reasons
not a good day for me....
only made 180 whp & 162 wtq 9psi
hopefully i can get this **** done soon and do my 225 whp mark
Modified by USDM 4G VTEC at 11:11 PM 10/4/2004
Old Sep 28, 2004 | 08:16 PM
Sinner's Avatar
redlining at 4k, where you in limp mode? 180hp at 4k isnt to bad.
Old Sep 29, 2004 | 06:25 AM
Default Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">redlining at 4k, where you in limp mode? 180hp at 4k isnt to bad.</TD></TR></TABLE>
no
on the hack i made 180 whp & 162 wtq
on the turbo edit basemap i was doing about 105 whp when it cut
Old Sep 29, 2004 | 06:55 AM
AspectIndustries's Avatar
Default Re: (USDM 4G VTEC)
Try Uberdata?
Old Sep 29, 2004 | 06:57 AM
SL0WEGG's Avatar
Default Re: (synik)
uberdata is for obd1 and turbo edit is for obd0 mang
Old Sep 29, 2004 | 07:30 AM
Ckjeepin's Avatar
Default Re: (boostedej1)
maybe you had launch control?
Old Sep 29, 2004 | 07:38 AM
blundar's Avatar
Default Re: (Ckjeepin)
most bins do ship with launch control enabled at 4000RPM by default...
Old Sep 29, 2004 | 07:55 AM
yea after the second run i noticed the launch control
but wouldnt it enable the regular redline after 8mph???? i had it on 4th
anwyays when i took the launch control OFF
it didnt redline on4k on neutral, but once on the dyno it did redlined at 4k
Old Oct 4, 2004 | 07:11 PM
Default Re: D16Z6 + 14B + Dyno = ....... (USDM 4G VTEC)
Old Oct 5, 2004 | 08:48 AM
Vtec92Civic's Avatar
I should feel bad after seeing that because I had a t3/t4 on my d16z6 head/y8 block at 10psi and I only made 188whp 150wtq, so don't feel bad man, but I got a Built LS now that I am breaking in so hope that goes well so I can get her prepped for boost.
ilovejdm
Mar 15, 2007 08:24 PM
HCJDM1
20
Jan 30, 2007 11:30 AM
civic93@8psi
Nov 4, 2005 12:00 PM
Skank_aSS_Dara
Mar 27, 2005 01:18 PM
USDM 4G VTEC
11
Oct 9, 2004 05:43 AM
