Civic SRS/ Airbag light
Old Sep 28, 2004 | 04:35 PM
b18c-ivic_gsR's Avatar
Default Civic SRS/ Airbag light
I took my steering wheel off my car to put on an after market one but it didnt fit so i put the factory one back on and the srs light came on.? so i unpluged the battery and checked the fuses and srs connections but its still on !!! Can someone PLEASE help me get this light off, without just taking the bulb out???
Old Sep 28, 2004 | 04:39 PM
Mikey-G's Avatar
Default Re: Civic SRS/ Airbag light (b18c-ivic_gsR)
I don't think you can get another steering wheel, because you have the srs.
Same with mine. So.. i wouldn't know exactly how to correct the problem
Old Sep 28, 2004 | 05:08 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Civic SRS/ Airbag light (Mikey-G)
Here is a link that might be helpful. I had the same problem last week and this cured it. Good luck! https://honda-tech.com/zerothread?id=264288
Old Oct 11, 2004 | 08:45 PM
Default Re: Civic SRS/ Airbag light (NVturbo)
Just got my car back from putting a b18 in it and i tried the jumper thing and it worked on the first try thanks alot!!!!!! your a life saver and a wallet saver too!!!!
Old Oct 18, 2004 | 08:04 PM
NVturbo's Avatar
O.G. triple O.G.
Anytime I can help a fellow HT member out.....
Old Oct 18, 2004 | 08:07 PM
civic00's Avatar
mine came on when i changed out the gauge cluster. any suggestions
Old Oct 18, 2004 | 08:52 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Civic SRS/ Airbag light (civic00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic00 &raquo;</TD></TR><TR><TD CLASS="quote">mine came on when i changed out the gauge cluster. any suggestions</TD></TR></TABLE>
Did you plug the "yellow" two-wire connector into the back of the cluster? That is for the SRS light indicator.
Old Oct 20, 2004 | 08:09 AM
civic00's Avatar
that did the trick thanks alot
thewrai6th
Jan 15, 2009 05:28 PM
92ehatch
Jul 30, 2006 05:57 PM
pennies_hatchie
Oct 20, 2005 07:14 PM
itr-j
Nov 27, 2003 06:21 PM
AmginE
Nov 13, 2002 08:04 PM
