I want more compression
Old Sep 28, 2004 | 03:57 PM
fastsohc's Avatar
Default I want more compression
I need to know if anyone has decked the f23 head for compression.
I also need to know how much to shave safely of the surface to get about 1.5points
thank you
Old Sep 28, 2004 | 05:38 PM
MrMike's Avatar
Default Re: I want more compression (fastsohc)
u got a couple of options to rais compression. i ranked them top to bottom, top being the best way to do it.
1. Pistons
2. Welding head chamber(squared or clovered)
3. Flat faced valves
4. Thinner head gaskets or removing plys
5. Shaving the head
6. shaving the block.
Shaving the head and block are not the best ways to raise compression in my opinion cuz once u do it u can't go back and u may run into timing belt problems and offset ur cam timing
Old Sep 28, 2004 | 06:11 PM
fastsohc's Avatar
Default Re: I want more compression (MrMike)
is removing plys difficult?
Old Sep 28, 2004 | 09:50 PM
SPEEDCORE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrMike &raquo;</TD></TR><TR><TD CLASS="quote">
........... u may run into timing belt problems and offset ur cam timing</TD></TR></TABLE>
I knew about the cam timing but timing belt problems??
Do you mean like possible to have a slack fitting belt? I thought this could be over come with more adjustment on the tensioner.....
MyWhiteEJ6
12
Nov 10, 2013 06:38 PM
RockLee`
Oct 29, 2006 03:43 PM
cashshoes
16
Jun 16, 2006 10:15 AM
.RJ
May 8, 2003 10:45 AM
ic108
Jul 18, 2001 04:36 PM
