HOw to install Gauges????
hey can someone help me out....i have two guages, an oil pressure and water temperature....i got the pod and everything but just need to know if someone can help instruct me to installed it.....all i know is that one is an electrical and the other one is mechanical....please help me....
YEs... they do come with instruction but in this case the instruction is not helpful and there is no diagram for u to use as visual aide.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">If you were in So. Cal i could install them for you. Its pretty easy. First off which is mech. and which is electric? </TD></TR></TABLE>
Luserkid: Do you think you could answer my questions about guages in this thread?
https://honda-tech.com/zerothread?id=709396
Sorry to hijack, but I thought the thread might help the original poster as well.
if the water temp sensor is made for ur car, the sender should screw into the hole where the radiator drain plug is. then you just have to wire for the lights on the gauge i think. then find your oil pressure switch, the gauge should come with adaptors to tap into the line. mine didnt, i found these at home depot for under 10 bucks. other than that, just wire for the back light for the gauge. find something that turns on when you turn your headlights on, like a bulb that lights up a button on your dash. pretty simple stuff. dont twist and tape, solder and heat shrink connections to prevent further problems. goodluck.
heel_touge
May 28, 2008 07:01 PM
