stubborn distributor rotor screw
Old Dec 12, 2001 | 12:41 PM
b18bvudoo's Avatar
New User
Default stubborn distributor rotor screw
somehow its kinda rusted and starting to strip when i try to unscrew it. this sucks. any ingenious ways to get it out w/o having to remove the distributor? i dont have a timing gun.
Old Dec 12, 2001 | 12:45 PM
rainforest's Avatar
Default Re: stubborn distributor rotor screw (vudoo666)
vise grips.
Old Dec 12, 2001 | 01:06 PM
b18bvudoo's Avatar
New User
Default Re: stubborn distributor rotor screw (rainforest)
screw it. i just need access to the wires to install a btm so i'm gonna cut through the plastic covering. it sucks that you have to remove the rotor in order to remove the plastic covering.
Old Dec 12, 2001 | 01:08 PM
Sonic's Avatar
If you can get your hands on an impact screwdriver it should work.
Old Dec 12, 2001 | 01:30 PM
RedlinedVTEC's Avatar
Default Re: stubborn distributor rotor screw (Sonic)
Just slot the screw with a dremel and use a standard screwdriver to take it out.
Old Dec 12, 2001 | 06:36 PM
b18bvudoo's Avatar
New User
Default Re: stubborn distributor rotor screw (RedlinedVTEC)
hey good idea i never thought about the dremel, and I have one too I was too lazy to deal w/ the plastic cover today but now I'll try w/ the dremel tomorrow. thanks.
Old Dec 12, 2001 | 08:22 PM
rioninja's Avatar
BTW, you should be able to pop the plastic cover off without removing the rotor. At least i have been able to on the dizzys i've worked on.
ebelp
Oct 31, 2019 05:32 PM
zairas
Oct 25, 2009 10:37 PM
zairas
Oct 19, 2009 03:08 PM
Tealeg88
10
Jan 15, 2006 08:43 PM
vtec.dc2
Aug 24, 2002 11:51 AM
