Oil leak, please help.
Old Sep 28, 2004 | 08:48 AM
JDM-EJ1's Avatar
Default Oil leak, please help.
I recently changed my oil, when the block off bolt dropped into the pan, I didn't notice the washer had fallen off, so I had a leak coming from my oil pan. I then relized the washer was off, and I put it back on, but I'm still getting a slight oil leak, the washer is on, and the nut is on there VERY tight, what could be the problem?
Old Sep 28, 2004 | 08:50 AM
snatch's Avatar
Default Re: Oil leak, please help. (JDM-EJ1)
Did you replace the washer? Don't torque the drain plug down too tight, that could give you problems too.
Old Sep 28, 2004 | 08:53 AM
JDM-EJ1's Avatar
Default Re: Oil leak, please help. (******)
No, I didn't replace it, I just used the same one. Everytime I change my oil, I use the same one. Yeah, I did torque it down pretty tight. Like, I can smell burning oil when I'm driving. So, you suggest replacing the washer and that should fix the problem?
Old Sep 28, 2004 | 09:00 AM
Deemeetree's Avatar
Electrician
Those washers crush when force is applied to it. You should NEVER reuse the washer. Once it's compressed, it's done. They are only a few cents at Honda. Pick a few up for future oil changes.
Never used the washer, had a drip or 2 here and there. Started using them, has been dry ever since.
Old Sep 28, 2004 | 09:41 AM
zman's Avatar
Default Re: (Dimi)
when you buy an oil filter from honda, which i recommend, they always give you a crush washer for the drain plug. Its just a shame that an oil filter from honda here in canada is $8.
Old Oct 1, 2004 | 08:12 PM
JDM-EJ1's Avatar
Default Re: (zman)
I always use a fram filter. But yeah, I should start using an OEM one.
Old Oct 1, 2004 | 08:27 PM
PRcivicHB's Avatar
Default Re: (JDM-EJ1)
Honda OEM oil plug washer = $0.31
Do your drive way the favor....
Old Oct 1, 2004 | 08:33 PM
Kamin's Avatar
definatley do not reuse the crush washers. and you smell burning oil because its dripping off the pan onto the header.
just drain the oil, redo the pan plug and washer, and refill.
Old Oct 2, 2004 | 01:20 PM
JDM-EJ1's Avatar
Default Re: (Kamin)
I just did that about an hour ago, I haven't needed to drive anywhere, but I will probably drive later on tonight. Hopefully the new plug and washer will help. Thanks guys.
Old Oct 2, 2004 | 02:32 PM
jeffk182's Avatar
I got my drain plug gasket from honda for FREE
tilhasbb
17
Aug 13, 2007 08:17 AM
I Like Hondas
Sep 25, 2006 04:39 AM
eg6ryder
Jan 4, 2006 09:02 PM
pinoyboy204
Oct 7, 2005 03:15 PM
